Old 05-26-2006, 03:33 PM
69 work in progress 69 work in progress is offline
Default ID 403 block
Where do I find the casting numbers on a 79 TA with a 403? Trying to determine if the engine is original.
Vince
Old 05-26-2006, 04:06 PM
jfmjr1 jfmjr1 is offline
Try the frequently asked questions section of http://www.442.com Has loads of Olds info on engines, heads codes where to look.
Engine ID on an Olds 455 (and I believe all Olds in this vintage) is on a pad, by cylinder #1, which may be blocked by power steering or alternator brackets.
Check out the FAQ section, it will help ID almost everyting, heads, carb, dizzy, exhaust manifolds etc
John
1965 GTO Clone 455 4 spd
1970 442 Convertible 455 auto A/C
Old 05-29-2006, 08:25 PM
olds olds is offline
Left side under the cylinder head front of motor. Flange just below the head. If the block has been milled/decked....the #'s are gone.
