Old 05-29-2006, 02:30 PM
bastereo bastereo is offline
Default POR 15 chassiscoat
today i was planning to spray the firewall and subframe with por 15 and chassiscoat black
my problem is that the directions for the chassis coat say to thin it 10-20%
the directions for por 15 say if needed thin 5% with por 15 solvent
what should i use to thin the chassis coat? it doesnt say that i need the special por 15 solvent but i dont really know what to use and not many places will be open tomorrow so I am hoping i can find what i need
oh and one more question about spraying the chassis coat over the por 15
should i spray the chassis coat when the second coat of por 15 is tacky just like i should apply the 2nd coat of por 15 over the first?
and do you think 1 coat will be enough
ok that should b enough questions for now
Thanks for all the help
Jon
Old 05-29-2006, 06:23 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
good question...do you have a local dealer?
the B&Z here in Modesto carries the POR line. maybe you can get the info from them.
Old 05-29-2006, 07:44 PM
flea flea is offline
Send a message via Skype™ to flea
My buddy sprayed his frame and underside with POR 15. He didnt thin it at all and it looks great! Use a cheap primer gun though
Old 05-29-2006, 11:25 PM
wlpsyp wlpsyp is offline
I have sprayed both. I did not thin at all. Sprayed well out of a el-chepo Home Depot sprayer.
Bill
_____________________________
It is not a problem.... It is just a blood pressure monitor.
Old 05-30-2006, 02:48 AM
good to hear that it doesnt need to be thinned that will save me the hassle of finding the right thinner
and i was thinking about it and 10-20% didnt seam like it would be enough thinning to make much difference
and i have a cheapo gun already so now i guess i can just do it
thanks guys
Old 05-30-2006, 07:55 AM
Bruce1223 Bruce1223 is offline
Not to whip a dead horse here--but be sure you wear a mask. I understand breathing por-15 particles is not good. Good Luck
Old 05-30-2006, 08:37 PM
chief many horses's Avatar
chief many horses chief many horses is offline
Jon
I know-- POR says use THEIR reducer, but I sprayed the chassis of a 72 Chev P.U. that I restored and reduced the POR as needed with fast drying laquer thinner - it worked great and is bullet proof 3 years later.
