View Poll Results: Leave headers black or paint silver?
Leave headers black 10 50.00%
Paint headers silver 10 50.00%
Voters: 20. You may not vote on this poll
Old 06-08-2006, 12:44 PM
OLDFLM72's Avatar
OLDFLM72 OLDFLM72 is offline
Default Black Headers - paint them silver or leave them black?
Need your opinions here... I've got a set of black Summit 4-tubes I'm about to put on... should I leave them black or paint them silver?
US Air Force Retired
"FREEDOMBIRD"
Old 06-08-2006, 01:35 PM
67ConvFB 67ConvFB is offline
I would paint them which ever color you like better. I sandblasted the black paint that came on mine off, and repainted them black.
Old 06-09-2006, 08:20 AM
Engo's Avatar
Engo Engo is offline
that paint will burn off almost instantly. you need to remove it and paint them with a high heat resistant paint. black would be my choice.
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 06-09-2006, 10:42 AM
OLDFLM72's Avatar
Default sand blasting
I've got a blast cabinet available at the base so either color paint will have a freshly blasted surface to adhere too.
OR they're black now... should I just leave the factory black alone?
V/R,
Ty
"FREEDOMBIRD"
Old 06-09-2006, 10:48 AM
Matt Danger's Avatar
Matt Danger Matt Danger is offline
Send a message via AIM to Matt Danger
If you leave that factory black alone it's going to burn off in a couple of hours. The best thing to do with painting headers is to get them sandblasted and then paint a hi-temp paint on them like POR-15's stuff or Eastwood's stuff, or get them ceramic coated, which is the best way to do it (but it's $$)
Any non-hi temp paint will just burn off quickly.
'71 Trans Am Clone
Old 06-09-2006, 01:56 PM
OLDFLM72's Avatar
Default Paint
Ceramic coating is not in the budget...
Even though I got these headers for free from Formula8! Thanks again Steve!!!
They'll get blasted and painted with either a black or silver high temp paint.
The poll is 50/50 right now so it's not really helping with my decision. LOL
V/R,
Ty
"FREEDOMBIRD"
Old 06-09-2006, 10:51 PM
Formula8's Avatar
Formula8 Formula8 is offline
Cool Ty, glad you are getting some use out of them. They have about an hour of run time on them.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 06-10-2006, 09:36 PM
OLDFLM72's Avatar
Default Pypes system?
Formula8,
What Pypes system did you put on your 71?
What muffler(s) did you use? Would you do anything different?
I'm looking at a new exhaust to put behind those headers you
gave me... (c:]
V/R,
Ty
"FREEDOMBIRD"
Old 06-10-2006, 10:33 PM
"Paint headers black" is not one of the choices but if it was, that's what I'd choose. I was told by someone at Summit that the factory black is only a coating to prevent rust during storage.
Old 06-11-2006, 03:57 AM
mothermuxer's Avatar
mothermuxer mothermuxer is offline
I ended up media blasting the old factory paint off of mine (box got wet & all the paint bubbled) & painted using POR-15 high temp paint (the cast iron colored stuff). Seems to be holding up well.
Old 06-11-2006, 09:25 AM
I've got that same set of headers. I'm planning to blast and paint mine too.
I was wondering about the Eastwood and POR manifold paints. Do they require baking/curing to get the heat resistance up?
I know that if you don't read the small print, you'd never know that some of the high temp paints don't really work without curing for an hour or so at 300~400 degrees F. It's kinda hard to bake a set of headers in the kitchen oven.
Old 06-11-2006, 09:51 AM
OLDFLM72's Avatar
Default They will be "re"painted...
The headers will get blasted and then "re"painted either black or silver...
"FREEDOMBIRD"
Old 06-11-2006, 12:05 PM
76transam76's Avatar
76transam76 76transam76 is offline
Get VHT header paint. I used the silver and it wont burn off. Actually it was the aluminum color and it looks really nice.
1976 trans am. 400 .040" over stock crank, CAT rods, speedpro flat tops, 72cc eheads, rpm intake, quick fuel 750, xe274, 1.5 HS. Built 700r4 (by me) w/3200 EDGE converter. 3.73's hustler headers. Flowmaster exhaust system. 17" torque thrust II's
Old 06-11-2006, 04:53 PM
Formula8's Avatar
Ty, I run the 2.5" X pipe (XVF10) and had to order the tails seperately since they didn't carry the muffler I wanted to run. I wouldn't do much differently. Maybe I would run the ultraflows or Xclerators but I'm happy with my Magnaflows as well.
Old 06-11-2006, 10:53 PM
OLDFLM72's Avatar
Default Pypes exhaust...
I'm definately going to go with one of their systems and like you said either the ultraflows or the 18" Xcelerators. I've been thinking about the crossflow system quite a bit but I'm afraid it would be too quiet... Tom Hand made a muffler suggestion to use with the crossflow for a little more rumble... what are your thoughts? I want something that sounds good at idle, quiet enough to hear the stereo inside the car without too much resonance, and I want it to roar when I hit the gas...
V/R,
Ty
"FREEDOMBIRD"
Old 06-11-2006, 11:43 PM
Formula8's Avatar
I don't think an 18" muffler will fit under the rear seatwells. It sounds like you want either the ultraflows or magnaflows. My magnaflows were very quite behind my 400. The new engine, not so much but still probably quieter than most anything else that flows well.
Old 06-12-2006, 12:01 PM
OLDFLM72's Avatar
Default UltraFlows
So you're running the 14" Magnaflows? The 14" UltraFlows are supposed to be "a little" louder than the 20" versions so that may be the sound I'm looking for... quieter but still have that musclecar sound...
V/R,
Ty
"FREEDOMBIRD"
Old 06-12-2006, 11:41 PM
Formula8's Avatar
Yep, my 14" magnaflows were surprisingly quiet behind my stock 400 with an X pipe and your headers. I think 14" ultraflows would represent a very nice compromise of flow, sound and fit.
Old 06-13-2006, 10:05 AM
OLDFLM72's Avatar
Default Crossflow?
What do you think about the crossflow system? Other than it's more expensive than the traditional dual muffler set up... ground clearance...
Did you have any clearance issues with your Magnaflows?
What headers are you running now? Just curious...
V/R,
Ty
"FREEDOMBIRD"
Old 06-13-2006, 11:49 PM
Formula8's Avatar
The rear of my car is stock height and whenever dual mufflers are used, you are going to lose some ground clearance. I can certainly live with my ground clearance. If you are running low, the crossflow presents probably a better option. I don't know what muffler was being used but I heard a sound clip and I can't say I cared for the sound.
I run a set of the elusive tribal tubes, Tri-Y headers from Ron Watt.
