Old 06-14-2006, 04:19 PM
MadHippo MadHippo is offline
Default fuel pump return line
Can the fuel pump return nipple be capped? I dont have a return line and i have a vented gas tank. I dont want to have to run the lines if i dont have to. What are the advantages and disadvantages?
thanks,
Matt
Old 06-14-2006, 06:56 PM
RobbMc's Avatar
RobbMc RobbMc is offline
Yes you can cap the return on a mechanical fuel pump.
This will increase pressure and volume by about 10 to 15%. This usually doesn't cause any problems but on rare occasions can cause flooding when using a Q-jet carb.
Capping the return will increase the chance of vapor lock but not anymore so than running a mechanical pump that doesn't have a return.
Old 06-14-2006, 11:28 PM
could that cause the engine to bog off the line? I have an edelbrock 750.
Old 06-15-2006, 12:43 PM
RobbMc's Avatar
Only if the carb is flooding.
Old 08-08-2006, 10:08 AM
mwritter's Avatar
mwritter mwritter is offline
What's the best method to cap the return?
I was told short piece of fuel line, bolt in one end, and clamped at both ends. Sound okay?
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
