Old 06-16-2006, 07:09 PM
jamesgennock jamesgennock is offline
Default 68-72 QUARTER GLASS INSTALL?
HELP! I can't figure out how to get the quarter glass back in? ANyone know? Thanks again.
JJG
Old 06-17-2006, 10:41 AM
3goats's Avatar
3goats 3goats is offline
Hey james
Thats the fun part. What works for me is don't bolt the window track in just lay it in the bottom first. Then with another person set the glass in and start the bottom roller in track then side rollers. Once window is in track start top bolts but leave loose.Then wiggle window crank roller onto window slider and install 4 bolts to crank. Glass is now in place and you finish installing rest of bolts and adjust glass as needed.
Much easier with four hands. Hope this helps.
Old 06-17-2006, 03:00 PM
engineer engineer is offline
procedure is in fisher body manual. works every time.
Old 06-17-2006, 07:17 PM
Ron Landis's Avatar
Talking Generally...
easier with two people. Remove all bolts from track. Install glass into track and line up and replace tracks. Simplest way we've found. No wrestling. Good luck. Ron
Old 06-19-2006, 11:58 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
Did mine myself, even made-up some rollers till I got my replacements (had the 1/4 glasses in/out a coupla times). My convertible is a weee bit easier than my HT though! Take your time, you can do it. Good luck
Old 06-21-2006, 12:39 AM
Talking
You guys are awesome!!!!!!!
JJG
