As many of you know Im restoring a 68 gto ram air 1 and I am needing a picture of the underside of the hood with the ram air pan. I have a new repro hood and it doesnt appear to be drilled for the pan.
Trent
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS. $90.00 fine for an awesome burn-out,worth every penny... http://www.youtube.com/watch?v=iI7beXh7xW8 |
Hope this helps - you can see the ghost outline of the pan on the underside. The 5 sheet metal phillips head screws are what hold it in - those are correct. Notice how the bracing has been cut - it looks smooth in the picture but don't run your fingers along it, because I think they cut it with tin snips.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
FYI
'68 Firebirds w/factory Ram Air also had a similar crude modification made to the Hood Inner for proper fit of the Hood Baffle & Seal. Since these were installed at the Dealership, the cut varies.
John '68 Firebird Ram Air 4-spd Conv. John 14:6 Semper Fi
Thanks for the picture. I didnt know that I had to trim the bracing!! Another unexpected dilema..
Here's a pic with the area highlighted and the pan installed
Thank-you.Mission accomplshed!
