Old 07-05-2006, 09:37 AM
Fullback66's Avatar
Fullback66 Fullback66 is offline
Default need help with left rear brake light
I am having problems with my left rear brake lights. Every once in awhile when I put on the brakes. The driver side brake light does not work. I just put in a new wiring harness from out host.
Question:
1. Did anyone else have this problem?
2. Could it be the wire harness under the carpet?
3. What should I look at next?
thanks
fb66
Old 07-05-2006, 10:38 AM
rgto273 rgto273 is offline
When I have that problem, its because socket for the light bulb isn't gounding against the frame of the car. So I have to move it around a little bit to get a good connection. I found a LED kit that I'm going to install, that should help and make the brake lights a little brighter.
Old 07-05-2006, 10:40 AM
george kujanski's Avatar
Does the directional work on that side? If the directional doesn't work either, than it's the bulb, socket, or the wiring going back. If the directional works but the brake does not, it's probably the directional signal switch.
george
Old 07-05-2006, 04:26 PM
67Tempest's Avatar
67Tempest 67Tempest is offline
I had a similiar problem in my 67... When I applied the brakes, both rear left turn signal/brake bulbs would short out, but only when I had the left turn signal on....
I replaced the sockets, checked the ground and traced it to the wiring harness underneath the carpet... I was lucky and found one on Ebay for 12 bucks...
I would also try replacing the brake-light switch on the pedal.... It's relatively cheap and easy to do, I have had those go bad on me as well.....
Old 07-06-2006, 07:39 AM
fred kobbe fred kobbe is offline
Default 66 GTO BRAKE LITE PROBLEM
JUST FINISHED MY 66 GOAT RESTO.HAD THE SAME PROBLEM WHEN I WAS DRIVING IT. FOUND OUT THAT THIS IS COMMON. IT'S THE TURN SIGNAL SWITCH BECAUSE ALL OF THE REAR WIREING GOES THRU THIS SWITCH THEN TO THE REAR.EVERYTHING ON THE FRONT WOULD WORK ,THATS WHAT WAS CONFUSING. BOUGHT A NEW SWITCH ,COMES COMPLETE WITH HARNESS FOR $75 FROM USA PARTS,FIT RIGHT IN AND SOLVED THE PROBLEM.DO NOT BUT A REPAIR KIT BECAUSE THERE IS NO WAY TO REPAIR THE OLD ONE BUY THE COMPLETE SWITCH.
WHEN YOU HAVE TIME CHECK OUT MY WEB SITE AT FREDSGTO.COM
LET ME KNOW HOW YOU MAKE OUT
FRED
SPENDIN MONEY HAVIN FUN FINALLY GOT ER DONE
Old 07-06-2006, 08:23 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Also, check the ground.
I had the same issue.
I ended up running a extra wire from the tail light housing to the body just to make sure I had a good ground. It solved my problems.
The tail light housing grounds to the body using the bezel studs and spin nuts, mine had fresh thick paint on the studs & body surface insulating the stud. (At least I thought that was my problem)
Also the new gaskets I put in probably didn't help the ground. Havent had a problem since.
P.S. I learned that star washers and dielectric grease on all ground wire points is alway's a good preventive measure in fighting electrical gremlins.
Good luck,
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 07-07-2006, 05:21 PM
Fullback66's Avatar
When I turn on the lights the rear lights work. The blinker works on the driver side. The brake light comes on sometimes. Not all the time, but sometimes.
67 Tempest,
Where do I get a brake light switch on the pedal? How did you run a ground wire from your tail light housing? Do you have any pictures?
Fred,
Would our host have the the wire harness that you installed?
Bob with 66,
I am not sure where the ground for the rear wiring is located. I do not recall any wires going to the body for the ground?
It has to be one of the thing you guys talked about. I need to do some looking.
Thanks,
fb66
Old 07-07-2006, 10:23 PM
Default directional switch
sorry about the laTE response was out of town. unfortunatly our host does not have the complete switch.usa parts was the only place that had them in stock. good luck
fred
spendin money,on fuel,havin fun got er done
Old 07-08-2006, 07:33 AM
Fullback66's Avatar
thanks fred,
I will check it out.
fb66
Old 08-31-2006, 12:38 PM
Fullback66's Avatar
Fred,
Is there a web site for USA parts?
Do you have a parts number for that harness you bought to fix the rear brake light?
fb66
Old 11-26-2006, 10:26 AM
Fullback66's Avatar
Fred,
Do you have a tilt steering collum? USA Parts does not sell the harness for a tilt colum.
Does anyone else know of a company?
fb66
Old 11-26-2006, 11:51 AM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
I had and issue where my signals worked but brake lights did not. Had to replace the turn signal switch.
Brad
Old 11-27-2006, 10:06 AM
Fullback66's Avatar
Brad,
Who did you buy the turn signal switch from? Does our host sell the switches?
Was it hard to install?
thanks,
fb66
Old 11-27-2006, 10:12 PM
Default 66 goat turn signal harness
fb66
my goat does not have a tilt column
just looked up in supply books,usa parts has onlt w/o tilt but ames has them for 64-66 with tilt. the part # is m139 it's on page 96 of the catalog and is $49 .
hope this solves the problem
fred
still spendin money havin fun got er done
Old 11-28-2006, 07:55 AM
Fullback66's Avatar
I see that our host PY sells them also. It is the (1964-66 switch w/ tilt....$49.00) part number GMI300. page 25
Fred.
Question:
1. How hard was it to install in your car?
2. Are there special tools that I will need.
thanks,
fb66
Old 11-28-2006, 09:36 AM
Fullback,
My car is without tilt, I replaced my switch. The only special tool you will need will be a steering wheel puller. The switch is mounted with screws, the chrome lever has (1) screw and the switch wiring just plug's in.
You do have to remove the lower column mount and slide the wire cover off the column to take the old switch out and to load the new switch.
I replaced mine a couple of years back, maybe someone else will remember any other things that need to be done.
It didn't take long to do.
Old 11-29-2006, 08:26 PM
Fullback66's Avatar
thanks Bob,
I found my X-mas present.
fb66
Old 11-30-2006, 08:35 PM
Default signal switch
bob is right thats all i needed.had mine installed in about a hour. course 30 min of that was b'essing with buddies
sorry for the delayed response,was out of town.
this working takes away time to be working on the car.
good luck hope all goes well
fred
