Old 07-20-2006, 11:51 PM
sprechs69firebird's Avatar
sprechs69firebird sprechs69firebird is offline
Default Max Wheel for Stock Height Suspension
Does anyone know the biggest front and rear tire/wheel set up can be run on a '69 bird. I'm planning on keeping the stock ride height on the suspension rebuild. Maybe sometime in the future I'll run an air ride type set up, but right now I'm not going to spend the $. I am leaning towards a torque thrust style rim and thinking I can go 20" in the back and 19" in the front. Any thoughts?
Old 07-21-2006, 10:10 AM
2QUICK4U's Avatar
2QUICK4U 2QUICK4U is offline
I just put on 18" all the way around with a 40 series tire and they seem to be fine. But I haven't driven it on the road yet just my driveway. Hopefully this weekend I'll put some miles on the 67 bird and let you know if I have any problems.
If you're not liven life in the fast lane, get the hell out of my way
1995 Trans Am LT1 **SOLD**
1967 Firebird 326 ci: headmenn headers, rpm manifold, holley 670cfm street avenger, HEI
Old 07-21-2006, 05:20 PM
amcmike's Avatar
amcmike amcmike is offline
I've 17s all the way around, but if I were to do it again, I'd probably do a 17/18 combo. Anything more looks silly to me and will cost a ton more in rims and tires.
Old 07-23-2006, 09:21 PM
jdbp jdbp is offline
I got 17's and my fronts rub when i hit a good sized bump.
Old 07-24-2006, 10:56 AM
amcmike's Avatar
What size tire, and do you know where it rubs?
Old 07-24-2006, 10:22 PM
225/45/17's they rub the out side lip at the top and i had to take out all my bolts and use botton head allen bolts.
Old 07-24-2006, 10:55 PM
amcmike's Avatar
Sorry for all the questions, but you have my curiousity up.
What width rim and backspacing did you use?
Do you know what your static camber settings are?
How long since the suspension was rebuilt(so, like age of balljoints and bushings)?
I have 245s with 1 degree negative camber and all new suspension including delrin (solid) control arm bushings. I have decent clearance to the outside lip even under compression, and it just barely rubs on the frame at full lock. It's only an issue on tight parking manuvers, but replacement tires will probably be 235s anyway.
