Old 07-28-2006, 07:27 PM
grnt37 grnt37 is offline
Question what the heck fluid?
There is trans fluid sitting on my intake manifold!I could not figure how the hell it got there,I found out it's going up my kick down cable and dripping onto the intake.What is the cause of this?a leak?
Old 07-28-2006, 07:31 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Maybe a plugged vent?? That's what I would check first.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 07-29-2006, 10:29 AM
TransAm525 TransAm525 is offline
You might be sucking ATF through the vacuum modulator line. Pull the vacuum hose at the modulator and see if you have a leak. If so, replace the modulator. Another possibility might be the transmission dipstick popping out under hard throttle and venting ATF vapor on the manifold.
Old 07-29-2006, 04:50 PM
I'll check those things out,and let you know.
