Old 08-01-2006, 11:01 AM
"Me" "Me" is offline
Default What motor is this?
I have a unknown in my 65 GTO, and I know it is not the original because I have that block as a letter sorting device in my office. I bought the Restoration Guide and Pontiac GTO id numbers but they are geared to GTO engines. I have not torn the motor down yet but it is a 2 bolt block.
By the distributor hole is what looks like 9778789. On the front of the block by the timing cover is YD with a 515052 production number just below the YD. There is no VIN #, so I am assuming it is pre 69, unless it is a replacement block. I will be tearing it down soon which will help I'm sure, but I am curious "NOW". Impatient old basterd, ain't I!
The heads are D port with 360 cast into the center exhaust, and D296 over2093 cast into the oil galley.
Is there a book that covers all Pontiacs that I could pick up to aid me in parts scavaging?
Thanks, Larry
Old 08-01-2006, 11:13 AM
steve's Avatar
steve steve is offline
i think it is a 65 389 but i have never heard of '360' heads..........
try this site...
http://www.yearone.com/updatedsingle...ontengid5.html
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 08-01-2006, 11:21 AM
72LemansFreak's Avatar
72LemansFreak 72LemansFreak is offline
I pulled this info from pontiac power racing:
http://www.pontiacpower.net/engcode01.html
YB B-body 65 389 256 Turbo 400 1x2 9778789 2 AC
So it's a 2bbl 389 for a full-sized `65. Had Air conditioning.
I can't find any info on that head casting number either. What other casting numbers are on them?
Regards,
Henry
1989 Trans AM GTA
Brilliant Red with Dove Grey Interior
5.7 TPI/700R4 3.27 "Aussie" Rear
1972 LeMans with Endura Option
Lucerne Blue with Black interior and Black Vinyl Top
400/TH350 (Sold)
"Wind in my hair, shifting and drifting, mechanical music, adrenaline surge..."
-Rush, "Red Barchetta"
Old 08-01-2006, 11:27 AM
steve's Avatar
72lemansfreak...i was a huge rush fan back in the day.....i always thought he said 'SHIFTING and drifting' not 'shaking and drifting'.
Old 08-01-2006, 01:44 PM
Those head #'s may have been 093, I had the motor upside down when I was looking at them? I will have to run back out to Wolverine Performance and take another look. I should probably see what year tripower manifold it has, if I remember correctly a 65 manifold will not fit on 66 heads? I'll read more.
If that is indeed a 65 2bl block is there any reason not to continue to build on it. Any differences? I am actually after a reasonably good performing street motor, that I can tweek for mileage for a round the U.S. trip.
Larry
Old 08-01-2006, 01:53 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
Originally Posted by Me
Those head #'s may have been 093, I had the motor upside down when I was looking at them...
Larry
lol. reminds me of the blonde joke where she walks into a parts store and needs a new "710" cap.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 08-01-2006, 03:01 PM
Once a Rush fan, ALWAYS a Rush fan...
Regards,
Henry
1989 Trans AM GTA
400/TH350 (Sold)
Old 08-01-2006, 03:14 PM
glhs#116's Avatar
glhs#116 glhs#116 is offline
You're right, Steve. It's shifting and drifting. As in SHIFTING gears and Tokyo DRIFT racing! I listened to that song often enough when I taught myself the bass line. Actually, listened to it tons before and often since. Great album. Like most Rush albums...
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 08-01-2006, 07:15 PM
Mean Ass 455 Mean Ass 455 is offline
Default casting numbers
hello Me check out Ken's Speed And Machine a vendor on the right off these pages lots of castings, heads ,engines all that good stuff and to #116 Ministry ROCKS!!
Old 08-02-2006, 01:47 AM
glhs#116's Avatar
"There's only one thing left for me to do, momma. I gotta ding-a-ding-dang my dang-a-long-ling-long!"
Great song. Something of a private theme song for my car...
Sam
Sam Agnew
Old 08-02-2006, 02:12 AM
goquick's Avatar
goquick goquick is offline
65 up manifolds have the same bolt pattern, but you have to watch the exhaust crossover size. Your 389 or 400 engine if it has the 093 heads, (i'd say it was a 389) is if i remember right appox. 8.6 rated compression. You can change cams and keep it mild enough to drive, get fuel anywhere without issues, and still enjoy it. Something like the Comp cams XE268H or their hyd. roller XR264HR or XR276HR (my choice)would work well.
Old 08-02-2006, 07:01 AM
This motor has been modifyed already, have yet to figure out compression and measure cam. It has crane gold rollers, the motor is fresh, crosshatch still showing as new in cylinders. It was pulling rocker studs, so I decided to pull it down and see whats up, check bearings, find out compression/cam profile while I have the heads off to install threaded studs.
Thanks a lot for your help and patience with me while I figure out Pontiacs, you guys are great!
Larry
Old 08-03-2006, 01:04 AM
goquick's Avatar
I would convert it to screw in studs or the problem will continue. ARP has studs to do the job with.
