Old 08-07-2006, 10:54 PM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
Default pictures of my new trunk install
just got done tack welding, tomorrow im going to seam weld everything
then im going to use primer/sealer. rubber undercoating and a few cans of that splatter paint on it, after i epoxy the seams of course, it should look flawless tomorrow
ID:	61283   Click image for larger version
ID:	61284   Click image for larger version
ID:	61285   Click image for larger version
Old 08-08-2006, 12:25 AM
cuz68's Avatar
cuz68 cuz68 is offline
Thumbs up
That is A great job. Well done.
Cuz68
Old 08-08-2006, 07:07 AM
Tinindian6702's Avatar
Tinindian6702 Tinindian6702 is offline
Great job! Good luck... I was always intimidated by a welding job like that.
1967 400 Firebird Convertible :
1978 Firebird Esprit
1980 Trans Am Pace Car (SOLD)
2002 RamAir Convertible
Old 08-08-2006, 08:55 AM
sandmanjoe's Avatar
thanks, it went pretty easy, the pictures that i posted were taken on day 2, im 16 hours into the job now, getting ready to go back out now and do the seams,grind,fill and paint, i should be done completely today. i hope, ill post more pictures tonight.
Old 08-08-2006, 11:45 AM
Verdoro 68's Avatar
Is the trunk floor supposed to be spot welded to the braces like it is on 68-72s? Seems like it would be.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 08-08-2006, 12:42 PM
sandmanjoe's Avatar
i bent the edge and seam welded both end parts to the braces, then seam welded the floor seams, you will never get that floor out without cutting everything out. its very strong! lol
Old 08-08-2006, 01:07 PM
65Tiger's Avatar
65Tiger 65Tiger is offline
Smile
Lookin Good!
Can't wait to see the new quarters and paint on it.
Old 08-08-2006, 01:45 PM
BILL BOWMAN1's Avatar
Be careful of that fuel line/pump!
Old 08-08-2006, 02:12 PM
sandmanjoe's Avatar
im high as sh!t from spraying the rubber undercoating and primer lol
im busting ass over here, got it all seam welded and primed/undercoated, now im getting ready to do a jet black base coat, then the splatter paint, should be done in 2-3more hours
Old 08-08-2006, 05:05 PM
sandmanjoe's Avatar
here it is, flawless! you cant see any welds anywhere, better then factory!
ID:	61335   Click image for larger version
ID:	61336   Click image for larger version
ID:	61337   Click image for larger version
ID:	61338   Click image for larger version
Old 08-08-2006, 05:13 PM
sandmanjoe's Avatar
Old 08-08-2006, 05:31 PM
bjohnson's Avatar
bjohnson bjohnson is offline
Nice job. Looks great.
Bruce Johnson
1970 GTO VOE HUMBLER
Old 08-08-2006, 06:19 PM
63RedCat's Avatar
63RedCat 63RedCat is offline
Sandmanjoe, what did you cover the weld seams with to start with? I am in the same procedure with my 65. Your looks great!
Old 08-08-2006, 06:24 PM
sandmanjoe's Avatar
POR15 in a tube epoxy,,, then bondo with fiber hair and toped it off with classic bondo, primer sealer, rubber under coating, jet black base, splatter paint
Old 08-08-2006, 06:40 PM
b777d's Avatar
b777d b777d is offline
Excellent job
Old 08-08-2006, 06:46 PM
sharkbite's Avatar
sharkbite sharkbite is offline
You should have used a few tubes of self leveling seal sealer on the wheels wells to trunk pan, that stuff is amazing, fills the smallest pin hole. If you haven't done anything with the underside of the trunk pan, I would definitely use some 3M Ultra Pro seam sealer on all the weld spots or any place two parts meet. Might as well make all that hard work last.
This world is your world, so take it, but take it easy.
Old 08-08-2006, 07:31 PM
65Tiger's Avatar
Smile
Great job! Looks better then mine!
Old 08-08-2006, 08:07 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Great job man, just wish I had that kind of time and ambition. Keep her going.
Send it! It’s going home on a trailer.
Old 08-08-2006, 09:12 PM
sandmanjoe's Avatar
thanks guys,,,,i timed myself on this job, from the old trunk and brace removal to paint took less then 16 hours over a 3day period, the pictures dont do it Justice, its a seamless/flawless job, some of the fastest and best work i have done. going to start on the 1/4 panels soon as i get all my parts.
Old 08-08-2006, 09:51 PM
Dave Wanichek's Avatar
Dave Wanichek Dave Wanichek is offline
On Vacation
Awesome work Joe! You should be proud of yourself!!!
