Old 08-09-2006, 11:19 PM
Philcol Philcol is offline
Unhappy Super T-10 leaks
I have even drained some lube cause I thought it was over full some way. Every time I take it for a spin around the block oil will drip off the bell housing and form a puddle on the drive. Nope it's not engine oil. I have the BOP seal and the crank area is dry as a bone.
I understand these trans don't have a front seal but use a slinger of some sort. So why the leak?
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
Old 08-10-2006, 09:26 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
My ST-10 leaked horribly when I installed synthetic gear lube. It also ate the synchros way too quickly (I was later told by Brian at S&K Speed in Long Island that the synthetic lube was likely the reason). When I switched to 85W-140 conventional, it never leaked a drop and the synchros looked great after several thousand miles.
What type of lube are you running?
Old 08-10-2006, 11:35 PM
Rocky, was yours leaking out the front pilot housing? I don't remember what lube was put in. I'll have to check. What else can cause this?
Phil
Old 08-11-2006, 09:54 AM
Mine leaked more from the flanges between the main case, mid-plate, and tailshaft. But it also leaked from the shift fork seals. Are you sure a gasket was installed under the front support collar?
Old 08-11-2006, 06:29 PM
Ken K Ken K is offline
ID:	61734   Click image for larger version
ID:	61735   Click image for larger version
