what happens when spark plugs get gapped at .025 instead of .045 on an HEI car? I just regapped all of the plugs to .045 and it feels like it has alot more power. Or am I just hallucinating because I spent all of that time changing the plugs through my headers? Thanks again guys
JJG |
I usually found that gapping the plugs "short" on an HEI setup resulted in a rougher idle......but no power difference between the two gaps sizes.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
It seems to start right up now as well without cranking much as well. Thanks
JJG |
If the ignition has the juice to fire it, a wider gap will result in easier startup and better cold idle because there is room to get more of the gas/air mix between the electrodes. Which was the whole reason behind the change to HEI--so the smog-era lean mixtures would be even drivable!
COOL! I learned something! Thanks bud!
JJG |
COOL! I learned something! Thanks bud! My mind is a sponge.
JJG |
