Old 08-29-2006, 02:44 PM
pedrog pedrog is offline
Question Engine OFF and oil pressure still UP. ???
Hello everyone. This is a great forum and I've learned a lot already from reading tons of posts. I am wondering if this is normal....
When key is not in ignition, oil pressure gauge is at zero. When I turn the key to ignition (engine is still off) the oil pressure gauge shows 40. When I start the car, it shoots up to 60. Just wondering if it is normal for the gauge to show some pressure even though the engine is off. The oil pump I have is a higher capacity pump than the original. I just recently installed that gauge.
Also, I have a voltage gauge that bounces around a bit (from 13 to 14 volts) the first few minutes after I start the car. Once the engine runs for a bit, it seems to stabalize at 13 when idle and 14 when driving. Volt gauge is also newly installed.
Thanks for any feedback!
It is a 1966 Pontiac 389 (I belive YC code).
Old 08-29-2006, 03:41 PM
Billy177's Avatar
Billy177 Billy177 is offline
no it is not normal.
is it a stock gauge, autometer etc? my guess would be either an incorrect or defective sending unit
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
Old 08-30-2006, 03:21 AM
form406's Avatar
form406 form406 is offline
ground?
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
