Old 09-02-2006, 11:54 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
Default 1969 8 Track Installation & 4 Speed Console
Can anyone explain or provide a picture regarding the installation of an 8 track player in a 69 with a 4 speed console? I have the mount for the automatic console and have seen the ones that mount directly to the floor, but never as requested. Thanks in advance.
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 09-03-2006, 11:49 AM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
I looked at the restro guide since the 68 and 69 mounting system is different.
Under the console there is a floor bracket. It has one mounting hole forward and two side holes. The top has four holes. Spacer sleeves go between the floor mount and the bottom side of the console. The console is sandwiched between the floor mount and the 8-track mount. The 8-track has side studs that attaches it to the upper bracket. At the bottom rear of the 8-track is a tab with a hole. Not sure if it is used on an installation with a console. Probably there to prevent the 8-track from swiveling.
Hope this helps.
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 09-05-2006, 07:01 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
If you don't have the 8-track mounting bracket that goes underneath the console you can use screws to screw the 8-track brackets
to the console top. If you have the bracket, the bracket screws to the floor
board underneath the console, then you drill holes in the console and the
8-track brackets bolt directly to the lower bracket with the console sandwiched in between. If you don't have the lower bracket and screw the
8-track brackets to the console, you will need to run a ground wire to the upper brackets or the 8-track won't play. The tape player's only ground
from the factory was through the brackets to the floorboard.
Old 09-07-2006, 03:02 PM
EBJudge's Avatar
EBJudge EBJudge is offline
Send a message via MSN to EBJudge
Here's a couple of pictures of one installed.
Name:	Judge Interior Christmas 2004.JPG
ID:	64508   Click image for larger version
Name:	Joe - Interior 1.jpg
"If your lawyer's asleepin' better give him a nudge,
everybody look alive, now here come th' Judge." - Sammy Davis, Jr.
'69 Expresso Brown/Gold RAIII Judge HT
'86 Carmine & Black/Red 1.8L NA Sunbird GT Convert.
'03 Montana EXT
Pontiac 1926-2010?
Old 09-08-2006, 12:08 AM
Good info and pictures. Is the under console bracket the same for the 4 speed and automatic. I hope so because I have one for an auto.
Thanks,
Larry Metzger
Columbus, NJ
Old 09-21-2006, 06:29 PM
j69shep j69shep is offline
Larry,
I have seen many of the under console brackets with the GTO players I restore, and I they are all the same, no difference between AT and manual transmissions. Look in the GTO resto guide there is an excellent pic showing the bracket and 8 track installation. Regards, Jim
Old 09-21-2006, 09:45 PM
Originally Posted by j69shep
Larry,
Thank You
Larry Metzger
Columbus, NJ
Old 09-25-2006, 11:17 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Default 69 8 Track Mount
Here is a picture of the correct floor mount bracket for factory 8 track player on my 69 Judge. You will also need the specific lower heater duct seen in the photo. Note it splits behind where the tape player would mount to avoid overheating the unit. Both these items are on ebay semi-regularly.
John
Email [email protected]
My Website www.minnesota-muscle.com
