Old 09-15-2006, 03:25 PM
65gofast 65gofast is offline
Question headers for 78 bird with 455
I need to find out if anyone makes a set of headers that would fit a 455 going into my 78 bird? I called Doug's headers they don't. Any suggestions?
Old 09-15-2006, 04:20 PM
2manyT/A'S's Avatar
Ask them for a 78 with a 400.
They SHOULD have that application for sure.
As long as your 455 has D port heads, they will fit.
Hooker should ALSO have a 78 400 aplication.
Old 09-15-2006, 05:15 PM
Larry Navarro's Avatar
Hedmann #28150.
I have recommended this header to lots of folks with the same question and they all agree that they fit the best over the others on the market. They also offer very good ground clearance. My '79 has cut springs and no problems on the road.
Less than $200
Old 09-15-2006, 06:26 PM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
What size tubes Larry?
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 09-15-2006, 09:03 PM
1-3/4" x 3"
#28150 for a Pontiac 455....not Olds.
Old 09-16-2006, 12:28 AM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
Larry, with your 4-speed, did you have to remove the backdrive linkage for the Heddman's to fit, or can you leave it on?
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
Old 09-17-2006, 11:26 PM
Old Goat Racer's Avatar
1978 TA martinique blue/ black int. (int. converted) 4-speed 455/96 heads
3.42 posi. Hedman headers 4-tube. All linkage in tact (backup lights work normally). Not much fun to install. Thinking about going to Hipo Manifolds when headers rust out. They've been on the car about 10 years. LOL
Old 09-17-2006, 11:37 PM
Alvin's Avatar
Alvin Alvin is offline
Cool
Yup - We have a set of H-O Racing Tri-Y's on our 79 4-spd that we are waiting considering doing the same replacement.
Old 09-18-2006, 12:04 AM
I figure I'll loose a few horses, but if it feels like too many there's a nitrous plate hangin on the wall.
Old 09-18-2006, 03:11 AM
loggerhead loggerhead is offline
I have Doug's Header's on my 1976 Trans Am w/455. These headers were not recomended for T/A's later than 1974. I called Doug's and they would not guarantee that these headers would work on a 1976 model. Mine are the round port variety as I have E-Heads. It is a 4-speed car which meant that the steering column lockout linkage had to be removed. I'm not sure but maybe the 1974 and earlier don't have a lockout linkage. Anyway this seems to have been the issue as these headers fit perfectly with no other modifications and are of very high quality. Hope this helps.
David
Old 09-18-2006, 09:09 AM
No problems with the backdrive linkage, everything intact.
Old 09-18-2006, 11:03 PM
Thanks for the info.
Steve
Old 10-20-2006, 09:15 PM
Pitch 400 Pitch 400 is offline
I called Doug's and they only said that the headers are'nt listed to fit later TA's because of emissions in some states.
Old 10-21-2006, 07:54 AM
Brian Baker's Avatar
I've used both the Hooker Super Comps in 1-3/4" and the Hedman Hustlers in 1-7/8" in my old 79 T/A. The Hedman's came with an adapter to fit between the header flange and the heads, which made isntallation a breeze. With the help of one other person, I had them on the car finger tight in 20 minutes. In your application, I'd go with the Hedman 1-3/4"
Old 10-22-2006, 04:47 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
I had the Hedman headers in a '78 and they fit great. I will likely use another set of Hedmans in my '81. I have Hooker Super Comps in the Ventura and they are OK but dont seem to fit as well as Hedman.
Old 10-23-2006, 07:06 PM
Default Headers on 455/78 bird
OK thanks everyone for the input, I'm going to SEMA so I'll talk to some of the manufactures. Hedman seems to get the most positive ratings though.
