Old 10-11-2006, 11:51 PM
Larry D Larry D is offline
Default Damn mice
Anybody know where I can get a breathable car bag for winter storage? Thanks, Larry.
Old 10-12-2006, 12:14 AM
GTOGreg's Avatar
GTOGreg GTOGreg is offline
http://www.autoanything.com/car-covers/69A1798A0A0.aspx
or
http://www.carvaluesplus.com/carbag_concept.htm
Is that what you're looking for?
1967 GTO
Tyrol Blue/Blk Cordova
400, TKO-600, 8.2 Posi w/3.55
400 + .020, decked to .005
SD Performance 240+CFM 670 heads
RARE HO/RA manifolds
RARE 2.5" Exhaust (18" Magnaflows)
SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL)
PRW stainless 1.52 roller rockers
Forged TRW slugs
SCAT H-Beam forged rods
Old 10-12-2006, 10:19 AM
Lanny Lanny is offline
Larry D
Try this for the mice -dryer sheets mice hate the smell of them and will stay
away from them and they make your car smell pretty good too .
moth ball DON'T work they just make the car stink!
Good luck
Lanny
Old 10-12-2006, 10:35 AM
dajudge_1970 dajudge_1970 is offline
Send a message via Yahoo to dajudge_1970
I have a "carbag" that I kept a '67 Olds Delta 88 ragtop in for roughly 3 months. My barn has a concrete floor and like any barn, has its share of rodents that like to make themselves at home in the darndest of places. These bags do not breathe so make sure the car is ABSOLUTELY dry when you put the car in it. The bags come with dessicant to draw the moisture out of the air, and worked well in my case. I also lined the bottom of the bag with oil dry matting to soak up any fluids that might leak while in storage. I also put plenty of dryer sheets in the car and the bag, should a mouse decide it wanted to chew through the material and see what was inside. I had good luck using it and will use it again when storing cars in my barn. The mice left the bag alone and my car came out of the bag looking as fresh as I put it in. I'd recommend one if you're considering it.
70 Judge RAIII 4-Speed HT (non-matching)
Old 10-13-2006, 12:21 AM
Default CAR BAG
Thank you guys. Will be buying soon.
Old 10-16-2006, 11:33 PM
Default Mice
O.K., car bag will prevent the mice, How about getting the ones who are there, out? Any suggestions anyone? Thanks! Larry. Check this out. Tonight, went to check on baited snap traps (with chedder), Cheese gone, trap not set off, and four dead baby's lying next to trap????????
Old 10-17-2006, 02:51 AM
Old Goat 67's Avatar
Get a good cat. Works for me.
Name:	DSCN2862 (Large).JPG
