Old 10-16-2006, 03:10 PM
65 Goat 65 Goat is offline
Default 326 to 389
Can I convert my 1965 lemans' 326 to a 389? Meaning, can I bore my 326 out to a 389? Are the heads the same and the intake? If I was able to find a 389 block, would any of my 326 parts fit, ( The heads, Intake, fuel, oil pumps etc.)
65goat
Old 10-16-2006, 05:32 PM
engineer engineer is offline
none, just unblock old block and install 389, transfer brackets unless 389 is 64 or older, then trans and starter issues. if 389 has provision to mount starter on block, you are good to go.
