Old 10-18-2006, 11:01 AM
robz's Avatar
robz robz is offline
Default GTO Hideaway Switch details..
I thought I'd post this for reference as I had it inside a different thread.
Here are 3 detailed pics of the hideaway switch in both open and closed position.
The 1st pic is of assembled switch in closed position.
2nd pic: switch unassembled, closed.
3rd pic: switch unassembled, open.
The rubber seal in the 2nd pic has a groove about 2 mm in depth to allow vaccuum to travel to nipples (hard to see in pic). Switch is in Closed position there (Seal is on left, covering nipples 2-3). In Pic 3 Switch is in Open position (Seal is on right, covering nipples 1-2).
That rubber seal slides over 2 adjacent nipples (1-2 or 2-3) when you pull or push the switch so that the feed (2) sends vaccum to either 1 or 3, to open or close the hideaways, respectively.
ID:	68757   Click image for larger version
ID:	68758   Click image for larger version
Old 10-18-2006, 11:33 AM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
Good information.
Here's some additional data for those with hideaways.
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 05-09-2007, 08:12 PM
Lemans51 Lemans51 is offline
Excellent!! Thank you for all the help.
