Old 11-02-2006, 04:36 PM
BILL BOWMAN1's Avatar
Default Changing firing order
Besides the cam change, the only other thing I would imagine would be changing the orientation of the plug wires. Is there anything else I'm overlooking, or any drawbacks to the swap?
Thanks,
Bill
Old 11-02-2006, 05:49 PM
bad69bird's Avatar
bad69bird bad69bird is offline
I don't think that there's any draw backs to the 4/7 swap. You might want to shoot Langer or Bruce Maichle a PM or e-mail. I know that they both have a decent amount of experience with the 4/7 swap.
-Brian
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 11-03-2006, 03:07 PM
Mr. P-Body Mr. P-Body is offline
Bill,
Chevys have been using this "swap" for many years. It helps "even out" the torque curve...
No other changes. The only drawback is that some may revert and put the wires on the "old" way, causing issues... It actually helps reduce the load on the crankshaft (the main purpose) and improves harmonics.
Jim
Old 11-03-2006, 03:11 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
Originally Posted by Mr. P-Body
Bill,
Jim
I'm not too familar with this, why isn't everyone doing it though?
Old 11-03-2006, 03:20 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Not everyone can just throw away their conventional Ch!T and buy new. LOL
fasteddy
Old 11-04-2006, 03:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Some of us have had 1-8-4-3-6-5-7-2 playing in the background of our brains too long- couldn't deal with a change!
Old 11-04-2006, 12:07 PM
RamAir6 RamAir6 is offline
They did this on "Horsepower TV" in september with a sbc. It gained around 30hp from what I recall. I would say that is a fair amount for the cost difference, I know I will be doing it on my next combo
Old 11-04-2006, 02:10 PM
Tom Vaught's Avatar
Boost Engineer
On Marty's Turbo Engine we looked at doing a Ford 351 firing order as that took the double firing hit (Number 2 and then Number 1) off the front main. This was a durability fix that Ford has used for years. The Ford 302 firing order is EXACTLY the same as the GM numbering EXCEPT that Ford numbers the cylinders differently vs GM.
Reher/Morrison did a lot of testing with the different firing orders and found that doing the 4/7 swap eliminated some of the heat in the back of the block from the 5/7 firing deal. The 4/7 deal still has the two front passenger side cylinders firing next to each other 4 then 2 and you still have the 2 then 1 front main double hit BUT the water pump discharge is much closer to the 2 and 4 cylinders so the double hit is cooled much better with the 4/7 swap.
Making power is based on looking at the whole system and trying to find the best compromised for best durability and power.
With a Belt Driven Supercharger there might be increased gain in durability of the crank with doing the 351 Ford firing order. With a NA engine the best combo might be the 4/7 swap. For a typical street strip deal the cost of the parts might not warrant the change. (Specially ground camshaft).
Everyones unique decision.
Tom V.
Old 11-04-2006, 02:59 PM
BVR421's Avatar
BVR421 BVR421 is offline
maybe they could have swapped 3 more pairs and gained 30hp for each?
Old 11-04-2006, 03:17 PM
BVR421's Avatar
Originally Posted by BILL BOWMAN1
Besides the cam change, the only other thing I would imagine would be changing the orientation of the plug wires. Is there anything else I'm overlooking, or any drawbacks to the swap? Thanks, Bill
The oddball cam blanks are a little pricey but then if you are swapping you are probably using expensive valve train parts anyway.
I think Indian Adventures or BOP (maybe others) sell swap blanks then you send them out to be ground.
Old 11-04-2006, 03:31 PM
Tom Vaught's Avatar
Boost Engineer
BOP is the only Pontiac company to actually have "round cams"
produced. You can buy the round cam from Butler, Spotts, Pontiac Dude, and others but it will come from Wade at BOP.
Wade really helped the Ram Air V guys and the overall pontiac community when he and Mark H. stepped up to having the cores made. JMO
Tom V.
Old 11-06-2006, 09:50 AM
For "high end" rollers, Comp uses the swap for Pontiacs. They have their own cores. We were told when we got the cam for the blown/alcohol project, that was the ONLY 50 mm cam core they have for Pontiac.
Jim
Old 11-06-2006, 05:01 PM
R 70 Judge's Avatar
I've been thinking of doing this with the 505 I have going together. Does anyone have actual dyno results before/after the swap?
I'm stuck running a Eagle crank in my engine so I'm interested in taking all the load I can off of the crank. --- Is it really that big of a difference?
James
1970 Trans Am
Old 11-06-2006, 09:48 PM
Don Kennedy Don Kennedy is offline
Default It did not help
The Timing change in one of my Super stock Motors did nothing for me
Old 11-07-2006, 04:11 AM
Originally Posted by Tom Vaught
BOP is the only Pontiac company to actually have "round cams" produced.
I've bought round-lobe Pontiac cams from both Lunati and Crower, and could also have bought from Crane. Are you saying that these three companies all get them from BOP?
Old 11-07-2006, 02:18 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Jack,
If you notice Tom said "Pontiac Company" However we have sold to most of the companies you listed. The deal is that we keep these cam cores on the shelf for customers so they have them when they need them. Most cam companies do not stock round lobe cores for Pontiacs. They often say they do but then call us.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 11-07-2006, 02:40 PM
Tom Vaught's Avatar
Boost Engineer
Agree!
Tom V.
Old 11-07-2006, 04:43 PM
So, I have to machine my block (IAII) to do the cam swap??
Old 11-07-2006, 05:38 PM
Tom Vaught's Avatar
Boost Engineer
The "round cam" allows camshaft people to put a given intake or exhaust lobe anywhere in the 720 degree firing order. It also allows them to but what ever lobe separation they want and what intake centerline they feel is best.
You will not have to machine your block to use the cam if the correct cam is ordered for what you are trying to do.
BOP offers round cam blanks that work with factory block bearings as well as race applications.
Tom V.
Old 11-08-2006, 03:49 AM
Originally Posted by Wade Congdon
... we keep these cam cores on the shelf ...
Thanks, Wade, for setting me straight. Do you stock both cast iron and steel blanks?
