View Poll Results: Which engine with stock heads?
'69 400 with 62's 15 32.61%
'74 455 with 4x's 31 67.39%
Voters: 46. You may not vote on this poll
Old 11-11-2006, 02:21 PM
MetalHead175's Avatar
MetalHead175 MetalHead175 is offline
Question 400 or 455?
So I've been building my 70 Firebird for quite some time, and gathering info on the way. This is going to be a street/strip car. However I've come to a road block now that it's time for the motor to go in. I have a '74 455 with 4X heads (low compression ones) that I was going to put in it. I also have a '69 400 with 62's and was i believe a factory 350-375hp engine out of a Grand Prix. Both engines are rebuilt, and I won't have enough money to secure heads for the 455. So my question is, which one should I go with temporary before I build a race motor? I'm leaning towards the 400, but I like the torque and cubes of the 455. However, with less money the 400 makes more horespower...Both engines will have the same manifold, ignition, headers and decent sized cams. I will eventually build the 455 to go into the Firebird but I need something to kick around with now. I know nothing about 400's so cam suggestions would be helpful too What do you guys think?
1999 Trans Am Ws6 Slp Lid, K&N, Smooth Bellows, Ls6 intake, Spec Clutch, Spec Alum. Flywheel, Spintech Cat back.
1970 Firebird Esprit 455 Pro Street project
Old 11-11-2006, 02:41 PM
BILTIT's Avatar
BILTIT BILTIT is offline
The 400 w/62's will be too much compression for pump gas without the right cam to bleed off some cyl. pressure (my 400 w/670's was the same way but i ran a RAIV cam which bleed off cyl. pressures.). Even with the right cam you will need some decent gears and conv. (if auto) to have this thing perform. I would personally put in the 455, even with low comp. it will have torque (more torque = more fun). It will be nice to run with 87 gas too.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 11-11-2006, 02:55 PM
Yeah i forgot to mention though that the car has 3.73 gears.
Old 11-11-2006, 03:29 PM
BILTIT's Avatar
I rough calculated the comp. of the 455 at 8.1:1 which is not as bad as you think. It would still pull hard with the right cam, timing, and carb adjustments.
The 400 would be about 10.2:1
Derek B.
Old 11-11-2006, 04:37 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Default Street/Strip
Even with the 3.73 gear your going to be much happier running the 455 over the 400. Don't be "Fooled" by the assumption the 400 rated at 350-? HP can or would be faster than the 455. Running 8.1-1 compression with the right camshaft, intake, ignition, and tires will make for a very strong running car.
EX: We built a 1976 Firebird with a Stock 455, stock iron intake, Lunati Bracket Master II cam .490/.490 @0.050 .230/.230 Adv 292, Comp 1.52 Magnum roller tip rockers, Holley #6213 Spread-bore DP (800 cfm), TH350 w/stock converter, 3.73 Auburn posi, and 275/60/15 Cooper radials. This car could not hook the radials at all and still ran 13.20's at 103 mph. There was alot more ET left in the combo with sticky tires!
We copied an article from HPP magazine, from a build up by Jim Taylor East Coast. On the dyno his engine made 390 HP @5200 rpm and 500+ ftlbs of torque. I can't remember the torque peak rpm, sorry. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 11-12-2006, 12:17 AM
Torque is what I'm after, is there really a huge difference in just 55 cubic inches? I think this thread helped me decide to do the 455.
Old 11-12-2006, 12:28 AM
BILTIT's Avatar
Its not just the cubes but the increased stroke.
Derek B.
Old 11-12-2006, 12:29 AM
mikeb mikeb is offline
455 hands down. You'll have to back the timing off on the 400 to stop detonation and it'll be a dog.
Old 11-12-2006, 01:02 AM
Hard-Timess's Avatar
Hard-Timess Hard-Timess is offline
Smile Prefer 400 over 455
My 400 Bird with Bullet 068 hydraulic cam out performs 455s hands down. See August issue #27 of High Performance Pontiac.
Now, having said that, if you are going to drive this on the street with todays available fuel, put the 455 in with the 068 cam, bring the 4x head down to 89/90 ccs and have fun.
Old 11-12-2006, 10:24 AM
gold bird's Avatar
gold bird gold bird is offline
Smile
455 it,s to much fun.
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19
http://www.youtube.com/watch?v=6PaHbLnszS0
http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109
http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60.
Old 11-12-2006, 01:30 PM
firebum firebum is offline
Hard-Timess,
How much off the 4X's to get 89/90/?
Thanks,
Jim
1973 Trans Am 4-Spd 455, #'s Matching
1973 LT/RS/Z28, 4-spd, 28K Milies, #'s Matching
1972 Camaro 4-Spd
1975 Camaro
2000 C5 Coupe
Old 11-12-2006, 01:40 PM
Ron H's Avatar
Ron H Ron H is offline
If you are going to modify the engines the 455 will win hands down.
68 Firebird
Are you running with the wind or breaking it?
Old 11-13-2006, 12:55 AM
Thanks guys! 455 it is... I'll let everyone know how it goes once I get it all done!
-Jason
Old 11-13-2006, 01:02 AM
BVR421's Avatar
BVR421 BVR421 is offline
you can pull two plug wires off that 455 and it will still beat the 400
Trumans 400 is indeed fast but it is not exactly a motor he just jerked out of a clunker and tossed in his Firebird.
Old 11-13-2006, 01:50 AM
johnsma22's Avatar
johnsma22 johnsma22 is offline
You can also just install a 455 crank (mains re sized to 3"), and standard bore 455 pistons in a .030" over 400 block, and stroke it! That will give you the best of both worlds. Longer stroke with the strength of the 400 block. You end up with a 455 on 3" mains.
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 11-13-2006, 11:57 AM
JLMounce JLMounce is offline
If it's not going to be a car that gets cruised a lot, you may consider swaping the 62's on to the 455.
I know I'm going to get flamed for this, but it's a great way to build power. Yes you'll have to keep a supply of high octane fuel, but especially if you're planning on building a race engine, you're going to need that anyway.
I currently run a .030 over 455 with 62's. The car is just stupid. Way more power than anyone could ever need. That's what makes it so fun.
-Jason
1969 Pontiac Firebird
Old 11-13-2006, 12:37 PM
That's not a bad idea, but I will cruise the car as much as I can. How much would I have to dish the pistons to get it into 91 octane pump gas range?
-Jason
Old 11-13-2006, 12:48 PM
-Jason
About 25 to 30ccs, 30 being best. Getting a 455 under 10:1 with 72-75cc heads takes a deep dish in the piston, custom Ross pistons can be made with the big dish.
Old 11-13-2006, 01:09 PM
The problem with going that deep of a dish on the piston tops is it really screws with quench. If you need lower compression the 62's on the 455 aren't going to be a very viable option.
-Jason
Old 11-13-2006, 02:42 PM
BILTIT's Avatar
Yup, i run 30cc dish in my piston with the 670's-72cc chamber. I am not sure i agree with the bad quench idea though.
Derek B.
