Old 12-02-2006, 01:16 PM
i82much's Avatar
i82much i82much is offline
Default manual trans combo's?
hey folks, i thought it would be cool to have a thread that's all manual trans combo's, something you could stumble upon by doing a search and get a bunch of good ideas.
i see more talk about stick cars at the track lately, that's awesome, you guys who know what you're doing can help folks like me out.
so if you've run your stick car at the track, post the combo and results here, and maybe some technique pointers too!
Old 12-02-2006, 06:49 PM
RAIV55 RAIV55 is offline
360 CI
Jerico 3.17
6.00 gear
14x32 Goodyear 1984's
30 Lb wheel
11" Mcleod adjustable plate with 1300 static
McLeod 4 puck 10 1/2" disc
3525 weight
10.65 @ 127.07
Old 12-03-2006, 06:19 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
400 .030 over
Richmond ST-10 4 speed 2.43 1st gear
3.90 Rear gear
Centerline dual friction clutch
3400 pound car
12.7's on regular old street radials
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 12-05-2006, 11:58 AM
Ashley P Ashley P is offline
6x-8, 1.77" exhausts, home ported. Iron intake, Q-jet, RA IV cam
Stock flywheel
Ram 6 puc disc
Centerforce DF pressure plate
Jerico w/2.93 1st
3.50 9" "Ford"
27x9
"Lightened" 78 TA. Maybe about 34-3500 w/me.
Shift points? Shoot, haven't even worked on that yet. Between 5k and 6k! lol!
60' about 1.7x
7.7x - 90.x
12.10-111.xx
VERY limited "tuning" on combo. My rear suspension hits to hard, but that was my only time at the track after putting in my 9" and tires.
Launch with pretty good track prep and 10-11 psi in tires had to be at WOT and above 4500 rpm. Anything lower or part throttle would bog. Again, I KNOW I have many things to change to even get in the "optimal" ballpark. With only driving changes I think I've got another 0.1 in 60', and possibly another .2 down the track with shift point changes.
Old 12-05-2006, 12:39 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Can all of you add what your launch type is and shift points.
That would help us "hang on and shift when you feel like it" kind of guy's!
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 12-05-2006, 02:01 PM
mikejub mikejub is offline
69 GTO...factory weight (whatever that is)
455 40/over, 10.4 to 1 (heavy TRW slugs), KRE heads (85 cc, unported), Crower 60919 cam (RAIV), 1.65 Scorpion roller rockers, Doug's headers, RPM intake, Cliff Q-jet
Liberty built Chrysler Hemi 4-spd (A-833 iron case, 2.65 1st gear), 12-bolt (Eaton posi, 33 spline Yukon axles, 3.42 gear, M/T 275/15/60 drag radials
Only tried it one time out...12.8 @109
Didn't get too many runs in...real busy day at the track...nor got to tune it in. But I must admit being a drag race rookie. Launching this car on the drag strip was nothing like on the street. On the street...just walk it out, short shift to 2nd and still can't hammer it down until I'm moving or just light the tires.
At the track...quickly discovered (once I got the tire pressure down to a level where she really hooked...18 lbs) that I needed to raise launch rpm well above anything I would try on the street. Started the day launching 2200-2500 rpm...car would jump, fall down, then pull hard the rest of the way (fun). 60 foots were poor 2.00-2.20 initially. Shifted at 5200.
Also needed to prepare in my head for the whole launch sequence in advance as doing burnout, pre-stage/stage, keep car from rolling forward, get rpm up and stable for launch, with lights already going down (it all happens fast). Like I say, being rookie, took a little learning.
But got better by the fifth and final run, which was my best time noted above (1.96 60 ft)...mph was always the same. Never could launch at more than 3000 rpm because of clutch issues (which have now been sorted out)...so always jump off the line, fall over, then go. Also never did power shift, ,which tried recently on the 1-2 for the first time with this car on the street, which really results in all hell breaking loose.
I was a little disappointed with times first time out...though still had a lot of fun. Pitted with some real friendly/helpful racers (that was part of the fun). Anyway they told me one should be somewhat disappointed on first try at the track, especially running a stick car. If there are bugs in the set-up...all will be made apparent at the strip, which may have gone unnoticed on the street. I think the regular racers here will agree...it will take some time to get the car and driver sorted out.
But I'm think with the car and driver dialed in for next time out next season...launching at 4000 rpm, hooking (maybe down to a 1.75 60 ft), speed shifting (5300-5500?)...hoping to get into the lower end of the 12s. Yee-Hah!
Mike
Old 12-05-2006, 02:46 PM
quicksilver97ta's Avatar
A two-step and a line lock if your serious at all.
I can't do the one foot on the gas and brake thing, so a line lock is the only way for me to do a good burn out. And I'm not even gonna try to look at my in-dash tach while watching the lights, forget it.
This narrows it down to adjusting tire pressure and launch rpm with the two-step. You can make it more complicated than that but I prefer to simplify it. 383/M6/4.10's 1.78 60' 7.82 @ 90.57 mph
Old 12-06-2006, 08:11 AM
Like was mentioned a two step off the line lock is the way to go. Improves consistancy ..... just one less thing to do after the tree starts down.
On my combo high limit was set at 8,000 unless I was in need of a better qualifing position at the cost of spring life. Usually left on the high limit and shifted at 7800.
I was instructed by McLeod to do burn outs in high gear.... don't ease into the clutch.... let it fly just like you're launching it.
Old 12-06-2006, 09:04 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
1969 Judge,
True street car in stock trim with a 400 and M-21 Trans.
Best time at the strip, 12.43 @ 112. Launching at around 2500, easing into it, shifting at 6k.
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 12-06-2006, 10:58 AM
Mordecai Mordecai is offline
2000 Camaro SS (3500# with me in it, no weight reduction)
stock 346" LS1
Stock T-56 trans
McCleod twin disc w/ aluminum flywheel
FLP 1 3/4 headers
Moser 12bolt w/ 4.11's
15" Draglites w/ M/T ET Streets (non radial)
Launched & shifted at 6k
1.78 60', 12.43 @ 11.4
7.9 @ 87 for you 1/8 folks
I'm planning an putting a T-56 in my '71 Formula, but that's a ways off in the future.
Old 12-09-2006, 07:28 PM
White Warrior White Warrior is offline
63 Tempest Coupe
3020# with driver
446" Naturally aspirated
Jerico clutchless 4-speed, 3.03 first gear
McLeod adjustable PP
sintered iron disk
5.13 gear 10.5w x31" MT's
Launch @6k
Shift at 8000 rpm
[email protected] with 1.29 60"
Old 12-10-2006, 12:23 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
RAIV455- Whoa! 360 c.i./3.17 Jerico/6.0 rear/8,000 RPM launch...
'Class' racer? What class?
I want to hear more about your combo- any threads on these forums for me to dig up?
Thanks.
Oh... he wasn't talking about a Pontiac.
Old 12-10-2006, 12:46 AM
KGTO's Avatar
KGTO KGTO is offline
1967 GTO 3700 w/ driver
416 with #62 d-ports and 150 shot
Jerico DR-4 w/ 2.93 1st
4.33 gears 28x10.5 M/T's stiff sidewall slicks
Mcloed street twin clutch
5500-6000 launch off 2-step
shift at 6500
10.28 @ 134
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 12-10-2006, 12:55 AM
guidos's Avatar
guidos guidos is offline
65 GTO
468
670 heads (dished pistons for a 9.5:1 comp) SD perform 265CFM
235/245 @ .050 on 110 LSA with .550 lift
66 tripower intake
1 3/4 headers 3" exhaust with "x" and ultraflows
TKO 600
12 bolt with 3.73 gears
Launch at 5600 off a two step and shift around the same point.
Best et 12.24 @ 113.3MPH at 3500 Feet
Just stepped up to a Mcleod dual disc but have not run it yet!!
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017!
Old 12-10-2006, 06:03 PM
i82much's Avatar
guidos your car sounds almost perfect.
Old 12-10-2006, 11:06 PM
guidos's Avatar
Thanks it is working good.....of course I want more hoping for 11's next year, but want to look stock, I am going to get some rally ones at some point, here is a picture.
Old 12-10-2006, 11:52 PM
firechicken's Avatar
firechicken firechicken is offline
77 TA
3800 lbs
twin turbo 068 cammed 400
ST-10 2.43 1st gear
3.73 rear
M/T DRs
SPEC Stage 3+
line lock
4000 rpm launch
1.72 60 ft.
= 7.29 @ 99 mph 1/8 and a busted St-10
Old 12-11-2006, 02:18 PM
i82much's Avatar
guidos - that's gorgeous, perfect stance, love that car.
Old 12-11-2006, 03:19 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
My other car
66 GTO 4000+ with me in it
389 Ported 093 Heads, 74 cc, (Tri Power) Pump Gas
Unitized Dist, Hyd roller cam
M-20 HD with Gear Venders OD
Ceterforce clutch and PP
4.11 12 bolt Posi
Adjustible upper control arms, Boxed Lowers, No hop brackets on 12 bolt to raise upper bars.
15 x9 x28 MT's
13.00's @ 105 Side step cluch @6000
shift 1st to 1st over,
1st over to sec over
sec over to 3rd over
3rd over to 4th
Very streetable, Blast hitting the OD button beside a newer fast and furious want a be.
ID:	75416   Click image for larger version
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
