Old 12-17-2006, 02:25 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
Exclamation timing
Setting dist. timing, what degrees?
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 12-17-2006, 03:47 PM
MAVbird76 MAVbird76 is offline
Brandi, since Pdude built your engine, he would know best. But for right now, just set the timing at 10 degrees BTDC. That will get you in the ball park. Hopefully your initial problem with carb backfires will be gone.
1976 TA, 455 4-speed
Old 12-17-2006, 04:10 PM
Brandi Kay's Avatar
thanks Mav
I got it at 12 now, im gona PM P dude in a bit, i'm awiting the engine to cool a little so i don't burn my hand tightening the bolt.
I appreciate your responce.
thanks
Brandi
:range r:
Old 12-17-2006, 07:13 PM
Probird's Avatar
Probird Probird is offline
After tightening the bolt recheck the setting you have. It's pretty easy to move the timing a little when tightening the bolt.
Old 12-17-2006, 08:12 PM
Brandi Kay's Avatar
roger, will do.
:range r:
