I'm replacing all of the fuel lines with new stainless lines and have one that I'm not 100% sure of the routing. The line is sort of "V" shaped and I think it mounts to the crossmember under the engine and connects the fuel return from the pump to the main fuel return line which runs inside the frame back to the fuel tank.
Is this correct?
____________________________________ "I work in high speed aluminum tubing." |
Yup. It runs under the engine to the passenger side. Then down the passenger side to the tank. You want a picture?
Less said,,,,,,,, Less mended. |
Thanks George, I'll be dropping the new mill in soon and needed to figure out the routing. Merry Christmas buddy.
I need a picture
Thanks, ARM |
![]() Quote:
The return line to the tank is not installed when I bought my car so I had to cap the pump return port and it's making my carb dump over and cause flooding in warm weather. |
It's the best picture I have.
