Do the flow advantages in blocking off the heat risers in the head justify the work involved?
yes
not a flow advantage, but a heat issue with the fuel in the carb.
Yes, a flow advantage on the 4 EXH bowls.
Yes, a reversion-contamination isolation-advantage on 4 & 3 vs 6 & 5. Yes, a cooler head temperature...in the middle-zone where the fastner shank show surface rust. Yes, a cooler head temperature...in the middle-zone where the head-gasket shown plastic deformation reflow...and likes to blow. I think it'sa good idea to Fill our crossovers, rather than blocking plates or leave open. |
Consider it a std op for headers.
Not just with headers- as HIS pointed out, 'sharing' of exhaust ports by cylinders 1/3 & 2/4 ain't good- reversion, etc.
Not worth half the effort on a street car unless already doing a major overhaul on the heads.
If race only then yes. |
I'd have to go along with BVR421 with a big "it depends."
What exactly are you trying to accomplish with the engine? If it's simply a strong street engine in a cruiser, then I don't see it as being worth the effort. If you're setting the car up for maximum performance, whether street or strip, then yes, it's definitely worth the effort.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
explain flow advantage? a reversion-contamination isolation-advantage on 4 & 3 vs 6 & 5.
if order is 1 8 4 3 6 5 7 2, and 4 6 are common with 3 5 common, how can the exhaust from opposite cylinders interfere? There is no back pressure from one on the other? |
