My Dad is having a bigger tri-power motor built (by Wayne Schicantek) for his 64 GTO to replace the four-barrel 389. He is pretty seriously thinking of going with one of these new overdrive trannies while we switch motors this Spring. He now has a Muncie/3:73's and kinda wanted a lower rpm for cruising the Interstate and so on without losing the off the line grunt.
My question is....Has anyone out there done this swap? Was it not too difficult? Any regrets? Any tips? I appreciate everyones input so I can show him the responses(he's got no access to internet). Thanks guys.
som2002 I am in process of doing this retro now .. Several here have done this and have given very positive feedback on it.. I dont have mine all the way in yet and it will be a bit yet but cant wait..
One thing many here recommended ClassicChevy 5 Speed for the tranny and kit vs Keisler due to their excellent customer support and I for one can vouch for that.. The guys at ClassicChevy are excellent and trustworthy to a tee. I recommend getting their kit. They have been most helpful for me...If only they could get a better name for their company...... http://www.classicchevy5speed.com/
I have no console but if did they have a shifter kit with some kind of offset that will accomidate the console...
Thanks Eric, I see on their website that they have a nice detailed walkthrough of an install on a 67. I'll have to print all that out and show him. Thanks for the heads-up on that site, all we knew about was the Keisler one, didn't know that we had other options.
Anyone else have any experiences or insight?
My buddy Phil posted a pretty detailed experience here: http://forums.maxperformanceinc.com/...ht=tremec+phil
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
I did the swap on a 67. Actually mine is the one on the classic chevy site. I would definitely, without a doubt say to go with their kit.
You will have to cut your tunnel to do this. If you are not willing to do major floor surgery, hit the BACK button now. Okay, your still here. What you will want to do if you are going to use a factory console is this. Cut the entire tunnel off down to the floorboard the full length of the console and the a few inches for good measure. Make some marks so that you can line it back up directly above where you cut it out later. You'll thank me for this later. Install your tranny and all that. Then lay something about 1/2-3/4" thick across your tranny. Like heater hose you could zip tie around the tranny at the high points or whatever. You are doing this to get your clearance so you won't have any rattles or vibrations off the floor. Lay the piece back over the tranny and make the hole bigger if necessary for you shifter. Probably won't be necessary. After you have it in place, use a couple of pieces of scrap, to tack it in place and then refabricate the gap that is all the way around the new relocated tunnel. This way your console bolts up just exactly the way you took it off and you carpet fits the contour nicely. you have made you tunnel bigger so you may need to go with a new piece of carpet because it may not reach the sides anymore. It will be the best thing you ever did to your car, but it is work. |
Hey, thanks alot guys. This will really help him out!!! And ClassicChevy sounds like the way to go.
Why is this paragraph even on the website? Quote:
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN
I looked at this route as I am redoing the drive train in my 1964 GTO for the same reasons, more performance, better highway cruising and just plain MORE FUN!
![]() I bought a Tremec TKO II (TR-3550) 5 speed, from www.moderndriveline.com and mocked it up with a bare block to see physically where the stock shifter was oriented and how much "modifying” was necessary to the transmission tunnel and floor boards. After removing the stock Tremec supplied shifter I ordered a Forte’s (www.fortesparts.com) 67-69 billet Firebird shifter and bolted it in place (the location was perfect when I bolted up a S.S. replica of the factory shifter handle - Bob L's idea) and then made the decision to not use the Tremec. The reason, too much cutting and modifying of the floorboards for my taste on a 60,000 original mileage numbers matching car. I am in the process of building a Muncie over drive transmission. It uses the basic 3 gear ratio’s and then instead of 4th gear being a 1:1 ratio it is 1:0.86. I plan to use this with a 3.55 or a 3.73 gear in the rear end once I determine the tire size. I see you are in Wisconsin, if you go the Tremec route and you are interested in the Forte’s shifter and a Hurst 5 speed white shift ball w/built in electric push button switch I will make you a super sweet deal (parts brand new, $400.00, sell $200.00). Hope this helps you out |
Some picture of my mods in a 65 GTO, there is one picture with the console on.....might give you some idea. http://members.shaw.ca/rguido just click on the black GTO
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
Thanks, did you see the pictures of the console on after the tunnel mods? I did not put the console in but I am sure it would of fit.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
Well, we did it. And a big Thanks to everyone with the ClassicChevy5speed tip. They were a great company to work with, and very friendly and helpful. No backordered anything. We actually finished the install at the end of summer but I just got around to setting a car page up for my Dad. There are a few pics of the install in his pictures on the 64 page. http://www.fquick.com/64goat Thanks again guys.
66 Cutlass Convertible (resto mod touring project) 69 Firebird |
SOM2002,
I see that the motor is a 455 with a 428 crank? So that makes it a 440 now? Im thnking of doing the same thing with my 66 Goat and with those 3.73 gears I was wondering how fast she is? Don
1966 GTO 1966 421-10.1-1 comp-Race Tec 23cc Pistons KRE Tri-Power KRE 65cc Aluminum Heads XE274 cam by Comp Cams DUR 230 Int 236 Exh @.050 - 110 LSA LIFT .491" Int .491" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
