| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
I need to find the frame mounts for my ventura to put my BBC in and how much will a 6 banger "glide" handle
Frame mounts will be the same ones used for a Nova with a BBC..........dunno about the glide, I would go with a TH400. A properly preped glide will work good in a drag car that is fairly light........like 3000 or less. If your gonna drive it a lot go with a TH400.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
The frame mounts are the same for any 67-69 camaro, or 68-74 nova to put the BBC there. The glide will probably handle 5-600hp if prepped correctly. The 1.76 "V-8" glide would be a better choice.
With the 6cyl glide you get a 'weaker' 1.82 ratio low gearset. I had a 182 low gear in my old chevelle with a 468 roller cammed braket car. I would come off the trans brake at 4800 rpm sometimes. The car was 3860lbs with me and ran a 6.90 eigth mile. It would have been MUCH faster with a TH400 but my 60 ft. times were in the 1.32 range on a 10 inch tire, carring the front wheels about 30 ft. Man I miss that car sometimes. Jim M.
Hugger was the glide prepped or was it stock
Hi Guy....You may want to sign up on the Team Nova site: www.novas.net They may be able to answer your tech questions involving the conversion.....In my opinion, a fully prepped glide would be ideal for the strip but not the street!.....I believe a good set up for the street for an excellent launch would be a built TH350, 3500 stall converter and a 12 bolt posi with no more than 4.10 gears!.....Or you could go with a muncie 4-speed with a heavy duty clutch assembly and a Hurst shifter!
The trans I had was built, but it did'nt have hard gears or anything like that. Jim M.
Thanks Hugger ands thanks 68 I did join the nova site too I'm actually on like four or five sites I'm kind of a knowledge junkie when it comes to hot rodding and drag racing I've been out of it for quite awhile and trying to catch up thanks again for all the input guys
my 71 had a 605 donovan in it before I bought it, glide and 410's, went high 9's.
John |
Slow build up of 72 Nova SS. 455 Pontiac engine 3 speed manual 8.5" 10 bolt Posi rear with 3.73 gears |
