Old 01-17-2007, 10:51 AM
billkinney billkinney is offline
Default interior paint
I have a 67 lamnas drop top completley beaded and in primer. Completely stripped inside and out. I'm close to paint and not sure if the inside of the doors should be the same color as the outside ? Is the dash semi flat black or does it too match the outside? The interior (seats and door panels and rag top) are white and I cant decide on an exterior color yet..
Thanks for your help,
Bill
Old 01-23-2007, 10:51 PM
What I'm asking is, did the factory paint the interior a different color? was the steering colomn different, the dash is semi-gloss black? The inside of the door was what color? Thanks,
Bill
Old 01-23-2007, 11:30 PM
I think you're having a problem getting an answer because there are so many possibilities. Cars got different interior treatment dependent on model and exterior color.
Here's a link that might help. Look at the trim code on your data plate and check for it on the reverse of the color chip sheet. Note: From the dropdown, choose Pontiac and not General Motors, then your year.
http://www.tcpglobal.com/autocolorli...arch/search.pl
Also, I think you might want to ask this in the specific model forum. I think the guys that know them best are the guys that have them.
Old 01-23-2007, 11:36 PM
Ooops....I just looked at the '67 Pontiac and they don't show the reverse side of the sheet. May be the same trim combinations that were available in '68 and they do show that info on those..
