Old 01-27-2007, 03:21 AM
Yellow Jacket Venom Yellow Jacket Venom is offline
Default '05 Tach
Does anyone know what the little circle on the right side of the tach face is for?
Old 01-27-2007, 12:07 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I assume this is on an 05 GTO? There is a factory shift light there I think you are seeing. But for some reason the factory never programmed it, crazy to put it in and not program it even for the factory shift point. There is a guy that has hacked the instrument cluster computer that can activate it. He can even do custom things like add your name to the display. He is on the www.LS1gto.com board often traveling around doing the installs.
