Old 01-27-2007, 09:17 PM
68GeeeTO's Avatar
68GeeeTO 68GeeeTO is offline
Default 68 GTO runs hot A/C ON at highway speeds
I reposted as engineer suggested.
My 68 GTO 400 is exhibiting the same symptoms, with the exception of it over heating when outside temps are 70F or less.
This is what mine does, overheating only when A/C is ON or OFF but, worse with the A/C ON and driving at freeway speeds.
When I get off the freeway, the engine temp comes down to normal.
I have a 160 degree thermostat, I can’t give you the exact temps because I’m going by the factory gauge. I know it runs hotter under the above mention conditions because it starts to spark knock and it will spit up a little coolant at the over flow hose when I shut it OFF. I know the fan clutch, needs replacing but the fan clutch should have no effect when I’m on the freeway because of the airflow at 70+ MPH across the rad and condenser. I’ve watched the coolant flowing through the radiator when the T-state opens, it flows very fast through all the cores and it even looks like it foams up a little because of the fast flowing coolant. The heater core is by-passed, and the radiator is a 4 core that has been re-cored about 5 or 6 years ago.
Any help is appreciated, Thanks in advance
Frank
Old 01-29-2007, 05:07 PM
68GeeeTO's Avatar
I just joined recently, did I post in the wrong section?
Anybody?
Old 01-31-2007, 01:18 AM
kk68's Avatar
kk68 kk68 is offline
I would replace the fan clutch. I seem to remember a similar issue when I first purchased my 68 as a daily driver over 20 years ago and I remember replacing the fan clutch after I tried everything else. Seems the clutch is important to pull air through the radiator...even at 70+ highway speeds.
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
