Old 02-05-2007, 05:56 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
Lightbulb To 4Link or not???
As some of you know I'm tubbing my car and goin ladder bar/coilover.
The plan is to do a full backhalf but try to keep my rear seat.
I like the street car look with full interior.
I plan on narrowing and reupholstering the seat to make it fit.
Most likely only one person will fit back there anyways.
I'm thinking though........if I'm gonna do all that work and most likely the
back seat thing won't work or will be too much $$$ I should just
4link it and be done with it. What are your thoughts?
Should I 4link it? I could sell my interior in the car to anyone with
a firebird or a camaro
. This would give me more $$$ to play with.
I've been debating on Kirkeys up front anyways for safety reasons
over the stock interior. Any ideas guys?
What are the advantages over a 4link compared to a ladderbar car?
Old 02-05-2007, 06:18 PM
BDHABT's Avatar
BDHABT BDHABT is offline
Car looks good the way it sits.Are those Cal-Tracs you have?Thats all you need.There are quite a few early Camaros up this way goin low nines on a 10" radial and Cal-Tracs.
I personally like a small tire car.
Keep us posted.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 02-05-2007, 06:24 PM
MrPushrod's Avatar
Keep us posted.
Caltracs have been sold
I want ride height adjustability, that's why I'm goin coilover
I love small tire cars also. I'll have either 325/50's or 315/60's on
the car.
Old 02-05-2007, 06:39 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Post 4 Link
My thoughts on the back half.My Firebird started out with ladder bars and then later switched to 4 link.As far as 60 ft,about the same,however the adjustability with a 4 link is far superior.Plus you should install a wishbone locator instead of panhard bar.It is much better.Make sure if you go 4 link to have the bars equall length and 22-23 inches in length.If you go with ladder bar set up than the bars should be approx,32-34" in length.Hope this helps on your decision.Good luck.
Old 02-05-2007, 06:49 PM
Goatman Goatman is offline
On Vacation
The car will always be worth more with a 4 link. Enough said.
Old 02-05-2007, 07:12 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
How did you come to this conclusion or is this your opinion
Old 02-05-2007, 07:29 PM
http://www.zapsrat.com.au/history.html
World Fastest Ladder Bar Car
Old 02-05-2007, 08:01 PM
wannabefast's Avatar
wannabefast wannabefast is offline
Friend of mine has broke his Mopar ladder bar car twice in the last five years causing damage to the rear, frame, and quarters both times. With the majority of the expense being in the installation of the equipment and not that much more expensive I would definitely go with the four link as the man said it makes the car worth more and gives you a foundation to go even faster in the future if you want. Art Morrison is the kit I went with and it starts around 750 with the good QA1 shocks.
Old 02-05-2007, 08:23 PM
MrPushrod's Avatar
Everything is being fabricated in house. My friend has a chassis shop.
He'll make the 4link.
Old 02-05-2007, 08:37 PM
On Vacation
Check the prices out there. Try using Mustangs, as they're the most common. Find two relatively identical cars and see what they go for.
The four link is superior in every way to the ladder bars and people will pay more for it.
Same deal with making a cage out of mild steel or CM. The CM car will be worth more every time.
Old 02-05-2007, 09:27 PM
If your friend has a chassis shop it should be a no brainer and I am not sure why you are even considering the LB... Do it right and do it once. I would hate to see that bird with a wrinkled quarter or worse.
Old 02-06-2007, 03:21 AM
goquick's Avatar
goquick goquick is offline
Owning serveral cars of both types, my answer is 4 Link !!! Use the wishbone set up on the bottom. Enjoy!!!
Old 02-06-2007, 10:51 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Ladders(as Im finding out) are known to hit the rear tires harder than a 4 link. They also seem to be a bit more temperamental on slippery tracks where as you may be able to adjust a 4 link to compensate. Ladders are limited to adjustability which to the novice would work well. But now with more power I think I want to upgrade as well because the car is not biting anymore. Even with 14" rear tires it wont hook up. So, avoid the "I wish I would have gone with a 4 link" scenario and do it now. You may need some help setting them up once you finish fabrication but Im sure theres a chassis shop in Reno that has scales and can get them close until you can fine tune.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-06-2007, 01:36 PM
MrPushrod's Avatar
Do you have any pics of your car and suspension you could post?
Old 02-06-2007, 06:15 PM
Half-Inch Stud's Avatar
All a matter of your 60foot goal.
See signature :
1.60 60foots were 5-leaf stiff stack with J-bolt Slap bars. 3.31:1 posi into 26" ET Streets. Full interior. Full Street driver.
1.50 60foots were slidin perch Ladder Bar with wheelie Bars. 4:10 spool into 29.5"slick. No interior. Race only.
It is a choice...
Old 02-06-2007, 06:21 PM
MrPushrod's Avatar
See signature :
It is a choice...
My 60' goal............1.50 or better.
250+ shot out of the hole.
Old 02-06-2007, 10:33 PM
79bluebird's Avatar
79bluebird 79bluebird is offline
go ahead and put a 4 link in it and call it a day. thats what is going under my 79 i just need to get a wishbone i got the pahhard bar now. going to do it all right the first time.
Old 02-06-2007, 10:51 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
if you have the means, im with about everyone else.. 4-link for sure
Old 02-06-2007, 11:03 PM
1.35 60ft Ladder bar car all steel motor built by potent pontiac 10 inch tire
Old 02-06-2007, 11:43 PM
455earlybird's Avatar
455earlybird 455earlybird is offline
I like my full back seat, cal-tracks, and 275/60-15 radial's good for @ least a 1.57 60' so far. It's not a race car though. I would like to build a race car and leave the bird a street car. Just my opinion though.
67 Firebird Best time 1.53 60' [email protected] 1/4 [email protected] 1/8 3500lb. leaf springs
