Old 02-15-2007, 10:19 AM
79transam79 79transam79 is offline
Send a message via AIM to 79transam79
Default USC/ all steel product
Has anybody used the product called all steel from USC. It's suppose to be a waterproof bodyfiller. Need to repair around the T top, mig welded all holes and sandblasted, and used chemical rust remover from por 15, now want to use this product I already bought just to smooth out the area, But curious if anybody had any issues with this product or is there something else I should us or do?
Old 02-15-2007, 10:35 AM
Region Warrior's Avatar
Used thier predecessor, but dont remember the name.
Also Duraglas. Has tiny fiberglass fibers in it.
Alot easier to work with then Tiger Hair.
Both worked good.
Old 02-15-2007, 11:42 AM
Default no fiberglass
This stuff doesn't have fiberglass, I believe it's just resin and aluminum. It's suppose to be as good or close to lead.
Old 02-15-2007, 12:00 PM
eric65's Avatar
eric65 eric65 is offline
I've used it and its similar to Evercoats Allmetal ... with aluminum in it works good sets-up like a rock the longer you leave it.. Work it just at the right time and its workable... Will last and be much tougher than regular bondo's for hole repair...
Good Luck
Eric
