Old 02-16-2007, 10:43 AM
The_Judge The_Judge is offline
Default Subframe 73 With suspension of 78
I have done some changes to my Sprint 73, I used a 78 TA subframe. Question I have to use the suspension of 78 or 73.
There is some difference between the suspension 73 and 78?
Upper Control Arm?
Lower Control Arm?
Center Link?
Tie Rod Ends?
Pitman Arm?
Idler Arms?
Joints?
Old 02-16-2007, 12:20 PM
TJH TJH is offline
IIRC, the only difference is with the disc brake rotors, which I believe will require matching spindles.
The spindle and rotor changed somewhere around 1978-79, but I can't remember exactly.
Old 02-16-2007, 02:16 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The lower control arms changed(and possible the spring pocket in the frame too) in 1977 as they require different springs. I think they changed again in 1979 when the spindles with the larger wheel bearings were introduced. I noticed my old '81 Trans Am had a much tighter turning circle than my '71 and '73 Trans Ams. The backside of the control arms looks to be more notched.
The center link and tie rods changed around 1975. The best idler arm is the '70-71 style. It uses a bearing. Later styles used a threaded rod and screw up and down as the wheels are turned.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 02-16-2007, 08:26 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
how did you get a 78 subframe to fit a 73 body?
Old 02-17-2007, 12:21 AM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
dens71, tell me more about the idler arm differences please.
to help the original poster, birds switched to the big-car caliper in 79.
spindle is different, one ball joint is different if i recall, rotor is different, one wheel bearing is different.
is this thing on?
Old 02-17-2007, 05:30 PM
mtnbikeair's Avatar
mtnbikeair mtnbikeair is offline
Send a message via AIM to mtnbikeair
I 2nd that question, because wasnt the 73 subframe longer by a few inches, like where the bolt holes were?
79 Firebird
71 Firebird
91 300ZX
Old 02-19-2007, 10:38 AM
To if I did it.
