Old 02-16-2007, 08:56 PM
BB1968's Avatar
BB1968 BB1968 is offline
Question Wheels on 68 GTO
Hey Guys, I am about to put some new wheels on my 68 GTO convertible, and I would like your input. Tell what you like and if possible post a pic of your car with the wheels you like. Also I want to make sure I am right with this, I think the wheels should 5x4.75 with 4.5 in backspacing. I want to use a 15x8 wheel. Someone please correct me if I am wrong. Also, I have heard of websites that you could post a pic of your car and change the wheels to get a good look as to what it would look like.
BB
Old 02-17-2007, 09:19 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
I'm running 15x8 Weld Prostars with 4.5" BS on a 68 hardtop. The tires are 28x11.5x15 Hoosier Quick Time Pros. they have a 11.2" section width,10" tread and are 28" tall. They fit without rubbing but if I had to do it again I'd probably go with 5" backspace since the outside of the tire is very close to the wheel opening on the quarter and there is at least 1" of extra clearence at the inner wheelwell.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 02-17-2007, 09:43 PM
naughtygto naughtygto is offline
Default Wheel to use
I have a 68 conv. also and I (and most other lookers) really like the Centerline pro stock Wheels. I have the most BS you can get from this wheel which is about 4.5. I still have 1" or more on the inside and "real" close to the fender. I use 275-50-15s. 12 " inches of tire is all I can get under the well without cutting. The wheels are 8.5. Sorry I dont have any pics right now.
Old 02-18-2007, 01:25 PM
BB1968's Avatar
TCS and naughty,
Thanks for the info I have draglites on it now. The rear is a 15x10 in. wheel and I want to go to a 15x8 or 8.5. I plan to run 275x60 on all 4 if I can. I talked to Summit and all they offer in the draglite is 4.5 or 5.5 back spacing. With a 60 series tire do you think it would clear? Now I have the wrong back spacing so I have to pick the rear up with springs to keep it off the tires.
Thanks for the info.
BB
Old 02-18-2007, 02:35 PM
Big Chief 541's Avatar
Big Chief 541 Big Chief 541 is offline
Talking 15x8 Cragar
SS, 4 inch backspaced
MY SHOP-MY GATOR MY RULES
Old 02-19-2007, 01:32 PM
BAW'D GOAT BAW'D GOAT is offline
Default Spacing
I run 285/40/R18 on a 10" Torque Thrust II with a 6.5 backspacing on a 12 bolt out of a 72 GP. Leaves about 1" on either side.
Old 02-20-2007, 12:25 AM
Ponchofan's Avatar
Ponchofan Ponchofan is offline
Send a message via AIM to Ponchofan Send a message via Yahoo to Ponchofan
Do you have any pics of your car with that wheel and tire setup? What are you running up front? I just put on 18x9-inch AR Rebels all around, with some too-small 245/40/18s at every corner. It could be me, butall the wheels look a little too far in. The rims all have a 5.9-inch back spaces and seem to work fine, even up front . There's 5/16 spacers at all corners. I'm thinking of installing 1-inch bolt-on spacers to help widen the stance, and 285/40/18s in the back.
Abe
New Yorker livin' in Oklahoma for now..
'71 Lucern Blue GTO It was originally Limekist Green and originally a 400/M21 car. But, it now has a 455HO (462)/M22 conversion.
'72 Quazel Gold GTO, '70 Polar White GTO (RAIII), '77 SE, '78, '80 WS6 Turbo, Trans Ams, '72 Grand Prix SJ. All Gone...
Old 02-20-2007, 04:45 PM
mcduck mcduck is offline
running 17" american racing polished torq thrust IIs on my 68 Convertible and get lots of compliments. Width 8" / BS 4.75". I'll have to double check the tire size, but I think I have 235/45s. They fit perfectly. You could do the same style in a 15"... should only have to change the tire size to get the correct overall height
Here's a pic...
Old 02-20-2007, 11:53 PM
BB1968's Avatar
Thanks guys, It looks as if I will be going with at least 4.5 back spacing. I do like the draglites and centerlines.
mcduck, can you put the tire inside your wheel well? I noticed that it appears to sitting up. I know you have the 17's on it, but I would like to lower mine so part of the tire is completely inside the well.
Baw"d, did you have to do much modifing to put that 72 12 bolt in your goat?
PM sent
Old 02-21-2007, 02:16 AM
roadrage david roadrage david is offline
im gong for 17x11x315 in the rear with 5.5 inch bs . seems that this is the max you can go. any confermation on ths??
Old 02-21-2007, 12:36 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
I had Cragar SS 15x7 on my 68 GTO before putting on 15x7 Rally II wheels.
Tires are BFG 225 or 215-65-15s. CRS has set in on the tire width.
Mike
Name:	GTO cragars MCEA.JPG
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 02-21-2007, 12:56 PM
PM sent
There are no rubbing issues. I've driven over steep driveway entrances and bumps which compressed the wheels and had no problems. Keep in mind I'm running a 4.75" backspace which means my wheels actually sit further in (toward the frame) than a 4.5" backspace would.
