Old 02-23-2007, 12:22 AM
Thumbs up Bathtub Tunnel Ram intake pics
I just thought I'd share some pics of the Pontiac bathtub repro intake I was lucky enough to get my hands on.
I figured I'd post them here in the Pontiac - Street forum since this intake will end up on a street car.
Needless to say I'm pretty stoked.
Old 02-23-2007, 12:35 AM
tom s tom s is offline
talk to Dave about any mods needed.Both of mine have a radius on the port intakes.Also Email me when you get time.Tom
Old 02-23-2007, 01:43 AM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
Any chance these will be repro'd again? I'd love to put one on my '65 GTO.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 02-23-2007, 03:57 AM
69LeManster 69LeManster is offline
sick! awesome score!
Old 02-23-2007, 11:13 AM
tempest455's Avatar
tempest455 tempest455 is offline
As it sits, curious, what's the over height to the carb flange?
Tempest455
Old 02-23-2007, 12:18 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
that is really cool looking.
post pics installed, please!
is this thing on?
Old 02-23-2007, 12:36 PM
Cool
That was one of the first things I checked when I removed it from the crate.
At the very front it's 6-1/8", at the back 7-1/4". I measured from the very bottom of the intake itself to the top of the carb mounting flanges.
Old 02-23-2007, 02:35 PM
65gto69's Avatar
65gto69 65gto69 is offline
Great score there b-man, awsome piece of history and thanks for the pics.
Now I saw one in pics, next will have to be in person.
1 more thing to check off my list of Pontiac stuff to see before I go....
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 02-23-2007, 03:06 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
oh sure...dont post any pics of the body mounts i sent you...lol
sweet intake, i can see why you couldnt wait to get your hands on it.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 02-23-2007, 11:46 PM
topdown's Avatar
topdown topdown is offline
I've seen first hand what a clay radius does to an intake port on the flow bench.
I can't believe there's no radius at all on this manifold.
Old 02-24-2007, 12:26 AM
Lightbulb
Well, consider that this intake was reproduced by a Pontiac nostalgia super-stock racer especially for racing. I'd say that this intake was definitely intended to be ported, port matched and even further worked-over in order be to run on a racing engine.
Adding a radius to the port entrances in the plenum is no big deal, and that's probably all I'll ever do to it. This is a very nice piece, rounding off a few sharp edges is about all that was left out in the casting process.
Old 02-24-2007, 01:13 AM
wheelspin's Avatar
Thumbs up I like it
Very cool piece, Bart.
You are going to need a lexan hood to properly show off your engine bay .
Les
Les Iden
Old 03-11-2007, 03:03 AM
Cool
A few mockup pics. No carbs, linkage or fuel lines yet.
I'll probably end up running it on some E-heads.
Checking carb pad height in relation to the valve cover rail.
Comparing to my RPM intake, the two gaskets sitting on the carb pad make up for the .180" that I had millled off of it.
A little bit of weld added to both front head corners will allow the '61 -'64 water crossover design to seal up. I'll have to plug and move some bolt holes slightly that seal the intake runners. Will also need to plug off and reshape the water passages at the front of the heads and drill and tap 2 new holes for the front crossover bolts.
I'll modify the E-heads heads to fit the intake, rather than the other way around. Or I may end up running on some early SD heads, still trying to decide.
You can see straight down to the intake ports in the heads from the intake plenum, some port matching will be needed of course. Ports at the manifold flange are pretty wide, averaging close to 1.200".
Old 03-11-2007, 02:42 PM
mucho coolo.
keep the pictures coming, especially the revamping to fit the late head design please.
very neat looking!
is this thing on?
Old 04-16-2007, 11:46 AM
Thumbs up
Moving along now, I managed to dig up a nice matching pair of 1966 389 auto-trans 4034S AFB (575 cfm) automatic carbs. I was able to find them right here on PY by posting a 'parts wanted' ad.
Now I can build up the linkage and fuel lines.
Old 04-16-2007, 12:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Really cool!!
Old 04-16-2007, 12:48 PM
White Warrior White Warrior is offline
I hpoe you like it.I should have made more of them before I sold the patterns to Randy Williams
Old 04-16-2007, 02:06 PM
Cool
Dave, saying I like it would be an understatement. I knew there was a very limited number of them made, so I snapped this one up while I had the chance.
I can't wait to see how this setup runs.If it runs half as good as it looks I'll be happy.
Old 04-16-2007, 05:01 PM
blown 68's Avatar
blown 68 blown 68 is offline
benn diggin' all your pics of late b-man, you've got a great take on the pontiac hobby. please keep us posted of ANY and all progress with your projects sir..........
davey
1968 Lemans/GTO clone, 6-71 blown 474ci
1969 Ram air III, Hardtop
(sold it to my dad!! still care taking for it)
Old 04-16-2007, 06:17 PM
Cool
davey
Thanks Davey, I'm more than happy to share what's going on in my garage and driveway with the folks here on PY.
I'm pretty hard-core when it comes to cars and Pontiacs especially.
Hard-core just like you with your passion for your rides and playin' rock 'n roll.
Myself I am in awe of musicians and singers like yourself who get up on the stage and lay it all on the line. Say hi to Storm and the Balls for me.
