Old 03-06-2007, 08:56 PM
bldinspector bldinspector is offline
Default ex.manifolds
does anyone know a website that lists the years and corresponding numbers for exhaust manifolds.
i am trying to find out if the numbers 9779328 and 9778032 are off of a 68 gto 400.
thanks
tom
Old 03-07-2007, 12:15 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
I know you can find the correct PNs in the GTO Restoration Guide.
As I recall the outlet size for automatics is 2" and 2.25" for manual.
Passenger Side should have a spring and weight valve for carb heating through the crossover in the intake manifold.
You don't mention whether these are logs or Ram Air?
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 03-07-2007, 12:36 PM
johnta1 johnta1 is online now
They are for 1966-68 GTO's.
Old 03-07-2007, 04:08 PM
engineer engineer is offline
try here http://www.teufert.net/pontiac/exhaust.htm
Old 03-07-2007, 07:39 PM
i was wondering if these would fit on a 70 400 motor?
thanks
Old 03-07-2007, 09:41 PM
goatless's Avatar
goatless goatless is offline
thanks
Yes. All of the A-body log manifolds are functionally the same. It doesn't matter if they're from a 326 or a 455. The biggest difference is that the early ones have the exhaust flapper as mentioned by runningbwdog. These were gone by '69. They all interchange though.
1966 GTO
Old 03-08-2007, 07:35 AM
gto4evr gto4evr is offline
Also keep in mind the early ones like 64 used 3 bolt flanges so if you're dropping old ones on newer car with an existnig exhaust system, you'll have a problem with the later model 2 bolt flanges not matching up.
Old 03-08-2007, 08:08 PM
fit depends on chassis configuration.
