Old 03-15-2007, 02:59 PM
JUDGEMAN70 JUDGEMAN70 is offline
Default 68 AC hoses
Where can I find all the AC hoses and lines for my 68 GTO? The PY catalog only lists one of them and I need them all.
Old 03-15-2007, 07:15 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Unless they are reproduced by Classic Auto Air in Georgia, you
will need to go looking in salvage yards.
Old 03-15-2007, 09:28 PM
68pongto's Avatar
68pongto 68pongto is offline
Only one hose needs to be reproduced, because only one has crimped ends. The other two that are connected to the back of the commpressor should be availible at an auto parts store. They are just barrier hose held on with special hose clamps. Old hoses from a salvage yard are junk! You will loose your freon, it will seep through them, especially if you use R-134.
Scott
Old 03-16-2007, 12:00 AM
cuz68's Avatar
cuz68 cuz68 is offline
Thumbs up
Very good awnser Scott.
Cuz68
Old 03-16-2007, 10:09 AM
I was assuming that you don't have the muffler, compressor
flange and hard fittings. If you just need the rubber hoses replaced and you have the hard parts then yes, you can change out the rubber hoses with
some from an auto supply store.
