I know this is old stuff but thought I would shed some light on the subject for the newbies that had not tried this before. Below is a pic that explains what can happen if you do not pour all of the aluminum at one time. This chunk let go in number five cylinder and bent the valve sticking it open. The good news is the car was idiling when this happened and the valve just litely kissed the top of the piston doing no harm. I heard it when it dropped the cylinder and shut it off.
Now for the rest of the story. This piece had been loose under the valve for some time. I had been previously smelling and odor coming from the car everytime it was driven long enough for it to completely reach operating temperature. It would go away when the motor was shut off. It smelled like burnt wiring but we could never track down where the odor came from. I had a slight exhaust leak at the manifold and you guessed it. It was right above number five cylinder. The aluminum would get hot rubbing against the valve and actually start to melt somewhat creating the mysterious odor.
"dreamed I was wide awake........woke up and I was sound asleep" |
Wow, considering what might have happened, you didn't come out too badly....I'd hate to see what would have been the result of the same thing at 5500 rpm instead of idle.
I've had a local PY member point me at a foundry that poured his heads....going to get a couple of sets done at the same time. Warm the heads and one complete pour, his came out fine doing that.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
I wonder what kept it from being blown out the exhaust port? Seems that the rush of the exhaust gas would have it sitting down at the muffler pretty quickly.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
The chunk was just too big to get under the valve or it would have been very bad. This motor had been buzzed to 7 grand just to be sure it would stay together. Hate to think what would have happened if it had stuck then.
Phil
