Prev Previous Post   Next Post Next
Old 03-21-2007, 10:06 AM
60man's Avatar
60man 60man is offline
Default Ready for dyno..Hot Damn...
Just to throw my hat in the ring...
Picked up motor a couple of weeks ago from Jack Gaydosh..had to swap out some parts to get it ready for dyno..
My thanks and kudu's to Jack, he's always first class at whatever he does..
Without his help I wouldn't have this motor..
My thanks to Brad Wallace (Wallace Engine Co.) for his machine work,friendship, and input to
New intake,headers, CSR pump, & dist. still on old motor..
Want to try out some stuff before switching to new bullet..
Hope to play with it at VMP...
All Pontiac.com IAII block
Crower billet 4.250 crank
BBC Eagle rods
Ross pistons & pins
Custom ground Chet Herbert solid roller cam
KRE D ports ..325 CFM set up for solid roller
Cometic head gaskets
Harland Sharp 1.5 rockers(for now)
Jomar rocker stud girdle
Bearing cam retainer plate ( Scott's) with billet timing chain set up
Power Bond SFI damper
Canton oil pan
TCI flex plate
Sorry no Stelka or fabed valve covers.
Need "Old School" look for NSS classes...
Old M/T covers will be back on after dyno...
Name:	IMG_1246 (Small).JPG
ID:	86015   Click image for larger version
Name:	IMG_1242 (Small).JPG
ID:	86016   Click image for larger version
Name:	IMG_1244 (Small).JPG
ECM member.
MANDRA
