Old 03-25-2007, 09:04 PM
beamy45's Avatar
beamy45 beamy45 is offline
Default another por 15 question
i have some metal that is part clean metal, and part is deeply pitted rust.
in some areas, i still have some existing paint in areas almost impossible to sand away.
will por 15 adhere to the clean metal and paint?
its not a car or anything that will be outside, its actually an antique safe that im painting for my boss.
so once its an antique, im guessing some of the old paint on there is 50-75 years old, but its stuck on there.
**edit...
if por 15 will work for this application, can i apply body filler and/or filler primer over it?
i realize the best thing is to get all the rust off, but i dont have access to a blaster, thats why im asking about the por.
boats before goats -mike diaz
http://velociraptor666.proboards106....ex.cgi#general
Old 03-25-2007, 09:48 PM
GTO Noob's Avatar
GTO Noob GTO Noob is offline
POR 15 is meant to go on over rust. It will also go on clean metal and paint. You will need to use metal ready to prepare the surface for painting with POR. I don't know about the filler.
Old 03-26-2007, 07:10 PM
hillpc hillpc is offline
I'd call the POR-15 guys and ask. They're quite helpful. I'm not sure it'll stick to paint long term. At the very least you should get it roughed up to provide some "tooth."
Old 03-27-2007, 12:52 AM
gtofreek's Avatar
gtofreek gtofreek is offline
My experience with POR 15 is what ever it gets on, it's pretty much there to stay! I got some on the oil pan rail of a block and couldn't scrap it off with a razor blade! Great stuff.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 03-27-2007, 10:11 AM
beamy45's Avatar
thanks, i appreciate the input!
