I have 2 questions. I recently looked at a 1969 gto conv. I wanted to buy, the rear passenger side inner fender was cut out, would a lemans conv. have the same inner fender? My other question is that the body/cowl tag was missing, is there a place that would reproduce these?
Hello,
All 68 and 69 inner fender wells are the same Tempest through GTO. You're talking about the trim tag and not the Vin plate? trim tags can be reproduced, vin plates can't. |
The inner fenderwells are available as reproductions too.
Here is a data tag company: http://www.trimtags.com/index.html |
slowgto, Thanks for th info. I appreciate the help.
Your welcome. Post us a couple pictures if it works out. With that data tag missing, double check everything to make sure it is the car represented.
Here is my '69 convertible. |
They cut pass inner fender wells to service the blower motor. Otherwise you have to mess with a lot of stuff--cutting it is easier than removing.
