Old 03-27-2007, 10:43 PM
stockcar32's Avatar
stockcar32 stockcar32 is offline
Send a message via AIM to stockcar32
Question Max Bore on a 400
Hi all, what is the maximum bore you can safely take a 400 out to? My WT code 400 is already .060 and I would like to freshen it up.
Old 03-28-2007, 01:01 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Some can be bored more than .060 and some can't. I've bored one .065 after having it soniced, but I've found blocks that couldn't go over .030. All in all, you need to have it sonic checked. I figure that a cylinder of .150" on the thrust side is the minimum for a non filled block, about .090 on the others.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 03-28-2007, 01:17 AM
stockcar32's Avatar
What kind of availability is there on Poncho pistons over .060?
Old 03-28-2007, 07:10 AM
The Boss's Avatar
The Boss The Boss is offline
You could also sleeve the block and go back to standard. It's about $50 a cylinder around here - may end up cheaper than custom pistons.
And go racin' in the street.
