Old 04-12-2007, 02:12 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
Default Reproduction Rocker Panel
Well today was one of those days where I ask myself, (Why am I even doing this?). I got over it real quick though. Upon removing the front part of my inner rocker panel, (on my 1970 LeMans convertible), I discovered that my outer rocker will also have to be replaced. It does not look bad from the outside but has rusty thin spots on the inside. So my question is about the quality and fit of the aftermarket rocker panels. Has anyone had any problems with the fit? Is there one company whose rocker is better than the rest or worse than the rest? Any opinions are welcome.
My first picture is from under the car.
My second picture is inside the rocker. It doesn't look too bad but the rust you see on the right has left me with paper thin metal. I pushed my thumbnail through one spot.
Paul
ID:	88360   Click image for larger version
I never met an old car that I didn't like.
Old 04-14-2007, 01:56 AM
3 Chiefs's Avatar
Default Anybody?
Anybody know anything about reproduction rocker panels?
Old 04-15-2007, 10:58 AM
keith h's Avatar
keith h keith h is offline
Hello Paul,
I went through this a few years ago ,almost no info on the net , I got mine from Goodmark ,it was tagged with the GM restoration part approval,no fitting problems ,the steel is quality , I think there is only one manufacturer of the rockers alot of companies have them drop shipped from goodmark and tag on a percentage for themselves so I ordered them direct.
ID:	88608   Click image for larger version
ID:	88609   Click image for larger version
370 Posts and holding...
Old 04-15-2007, 02:53 PM
3 Chiefs's Avatar
Default Thanks Keith
Thanks Keith. That info helps because I might by mine from Tamraz on ebay because that seems to be the best price. I know that they get a lot of their stuff from Goodmark. Thanks for the pictures too, that helps me.
Paul
Old 04-15-2007, 06:57 PM
eric65's Avatar
eric65 eric65 is offline
Thanks for Pix Keith but would like to chime in or hijack .. I have to replace a rocker panel due to looks to be a hit .. Have the rocker already but how eazy or hard is this to replace Is it just looking for all the spot welds and drill drill drill???/// Any tips or inprog pix before that appreciated...
Eric
Attached some pix of damage I uncovered
ID:	88637   Click image for larger version
ID:	88638   Click image for larger version
Old 04-15-2007, 07:01 PM
keith h's Avatar
No problem ,glad I could help ,if you need more photo's or have question's just ask.
Old 04-15-2007, 07:10 PM
keith h's Avatar
Eric
That's just about it Eric ,a little with an air sawzall ,a little with an air cutoff tool, what I did was trim off the old rocker down to where you can see the spot weld's ,and then peel off the old metal ,before you remove anything take alot of reference measurement's ,I used my digital cam and the ruler before I dug in ,I'll find some in progress photo's and post for all ,you can see in one of the photo's the brace I welded up ,from both hinge mount's and they both meet at the striker ,this way you are sure the car does'nt flex when you cut out the rocker
Old 04-15-2007, 07:12 PM
3 Chiefs's Avatar
Default Hey eric65
Looks like we are neighbors. Whoever takes the plunge first can help the other guy. Sound good? Just from the information standpoint, not really physical labor. I am not ready to cut mine off yet but it will be this summer.
Paul
Old 04-15-2007, 07:26 PM
keith h's Avatar
Take alot of reference measurement's and photo's and it should go well.
Good Luck ,I hope this helps
ID:	88646   Click image for larger version
Old 04-15-2007, 07:36 PM
keith h's Avatar
The holes you drill to remove the spot's come in handy when you plug weld the new rocker in place ,I used an air punch to make the plug holes where the rocker lay's over the floor pan ,also along the very bottom where it's pinch welded ,you might look into borrowing one of thoes tool's ,you won't want to use a hand punch ,or a drill it would take forever it's a heavier than stock steel.
ID:	88648   Click image for larger version
ID:	88649   Click image for larger version
Old 04-15-2007, 08:03 PM
3 Chiefs's Avatar
Default Thanks again Keith
It's amazing how many questions can be answered with a picture. Of course, it also raises more questions too. It looks like your floors and inner rockers were ok. The inside of my kickpanel will also need to be fabricated. I have the floor removed as well as the inner rocker, but only at the front drivers kick panel.
In my picture, I have put a transparent blue shade over the rusted area. If I make my replacement panel to cover the shape of that blue area, would that look right. With so much metal missing, its hard to know the details of that panel. Is there supposed to be any cut out hole or relief's in it? Is there any other shape to it other than flat?
Thanks again.
Paul
Old 04-15-2007, 08:36 PM
keith h's Avatar
Paul that's it a flat piece ,you can see it thru the holes in what's left of the outer rocker.
Name:	rcr front.jpg
Old 04-16-2007, 12:13 PM
eric65's Avatar
Hay Paul didnt realize we are close as that.... We will have to get together and check out projects...
Keith those pix are great help . One thing I didnt know is the inner rocker and outter... They I reckon are attached by a lot of spot welds all needing drilled .... I am just wondering how to start this and the extent of the drilling to get the old rocker off... Kinda wondering how much is involved in getting the welds off in the area behind the door and forward of the wheel well.. Is there spot weld underneath??? The pix are a great help though and i am going to do some measuring and maybe more braceing... I have to do floor pans also on this side but think putting the rocker in 1st is the way to start..
Eric
Old 04-16-2007, 04:04 PM
keith h's Avatar
Here are a few more shot's to give an idea where to drill ,and saw cut ,it's pretty easy when you see the new rocker what has to be peeled away ,I started by drilling the spot weld's.
Name:	rcr drill.jpg
Old 04-16-2007, 04:05 PM
keith h's Avatar
Old 04-16-2007, 05:06 PM
keith h's Avatar
Two more shot's of the drill/ cut line ,you can safely cut with a saw once your brace is installed then peel away the rest
ID:	88739   Click image for larger version
Name:	rckr cutdrill line.jpg
Old 04-16-2007, 07:02 PM
eric65's Avatar
Default rocker
WOW thanks Keith great info with the text added is great I owe you a 12 pack
Also thinking about area behind door included pix of area I am kind of guessing now to cut this area out then drill out or grind out connector spot welds
But wondering how this is attached
Eric
ID:	88763   Click image for larger version
Old 04-16-2007, 07:51 PM
keith h's Avatar
O.K. I see what you are asking ,photo 1 ,the rocker ,the floor, and the inner panel is like a sandwhich if you look from inside the car you will see the three together ( or at least that's the way it was on my car)that's why it's very important to make reference measurements. photo2, the area circled is the rocker itself ,if you look toward the right of your circles (The leading edge) you can see the pinch weld ,that's the rocker ,and inner backing ,what I did in that area is I used a small air sawzall and sliced it from back to front cutting the pinch weld's,the rocker came off in almost one piece from where I cut the top (sill plate) I can go snap some photo's if would give you a better idea ,let me know
Old 04-16-2007, 08:22 PM
eric65's Avatar
Thanks for that I would appreciate it greatly So in words just saw horizontal a litte under that seam and then cut once thats off
Thanks a lot
Eric
Old 04-16-2007, 09:04 PM
keith h's Avatar
In that area it's from inside the car and the area you lined ,you could cut that line then carefully grind off what's left ,once you get the new rockers you will see it a little clearer ,look at the panel covering the rear side window track ,it along with the rocker and floor are spotted together ,you could cut it there but you would still have to seporate the floor ,rocker and inner panel,again take alot of reference photo's and measurement's This is an old photo but it gives you an idea of what I'm talking about.
Name:	panel sandwhich.jpg
