Old 04-27-2007, 04:58 PM
punkey's Avatar
punkey punkey is offline
PY Staff - Tech
Default roof rail weatherstripping
Hello,
Does anyone have any helpful hints to replacing the roof rail weatherstrip?? I got most of the old stuff off but how the heck are you supposed to get in the back corner of the quarter window with out cutting through the quarter panel?? I was using the longest skinniest screw driver to pry it down and then going in with needle nose pliers to try to get the pieces out. But what a project, UGH!!! Is there any easier way to do this? I'm just afraid I won't get enough of it out and then I'll have problems when I go to put the new one down in there. I'm trying to get Punkey all sealed up since I got new carpet for my Bday
Come on Mom, lemme drive!!
Old 04-27-2007, 09:16 PM
GStage1's Avatar
GStage1 GStage1 is offline
You can always remove the Phillips screws holding the w-strip channel in place and remove it from the car...not that hard to do.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 04-27-2007, 09:49 PM
Anselcop Anselcop is offline
Stacy,
There is about 10 flat head screws that hold the stainless weather stripping rail in place to the roof rail of the car. Once you remove all of the screws, the trim that holds the weather stripping should come right out. There should be three pieces including the small corner chunk. Use some weather stripping remover, polish the stainless and re-install. Good luck!!
Dan
1969 Ram Air III 4-speed
1963 Lemans Convert #'s Matching 326 V-8
1949 Pontiac Silver Streak
Old 04-27-2007, 10:15 PM
punkey's Avatar
PY Staff - Tech
Thanks guys My boyfriend pointed that out tonight when he looked at it. He started taking the screws out but that channel is glued in also. So since I'm trying to make it to a show Sunday and I still have to put the entire interior back in yet we cheated. We got as much out with the skinny screwdriver and then pushed about an 1 1/2 extra wstrip through the hole so it should seal yet
