Old 05-25-2007, 04:53 PM
bfosterl bfosterl is offline
Default Anybody use a Saginaw Tran. for their 400 ci GTO?
I have a line on getting a rebuilt one cheap with Hurst shifter/linkage. I know their not a tough as a Muncie or Borg.
Old 05-25-2007, 05:09 PM
PONTIAC DUDE's Avatar
Thumbs down
They run great............... till they break. Torque and weight breaks trannies.
They put them behind 4 cylinder Vegas ............... as a reference.
Old 05-25-2007, 05:37 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
If you don't get on it very much it will survive for you. Like P-dude said they aren't real tough. Anything over 275-300 HP with anymore torque than probably a 327 Chebby puts out and you can be asking for trouble IMO....
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 05-25-2007, 11:32 PM
A.W.Dille A.W.Dille is offline
As long as you don't abuse it constantly it will hold for awhile. I've had them go after one to two months of hard strip use and have had them last for close to a season and a half, strip use and daily driving. Make sure your bushings in your shifter linkage are good and your shifter is in good shape and in perfect adjustment. Another thing to look at on Saginaw tranny's are the number of rings on the input shaft. Different ring count, different gearing in the trans, and heavier or lighter gears depending on the ring count. Hope this helps.
Old 05-26-2007, 12:25 AM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
mine lived a happy unbroken life in my 68 convertible, 10:1 400, small heads, small cam, with big tires.
i didn't beat the snot out of it by a long shot, but i don't drive like grandma moses, either.
when i was younger, i went though 3 or 4 in my 455 73 TA.
back then, they were worthless and i was hard on drivetrains.
make sure it's a v8 trans, not a short-geared six cylinder unit.
is this thing on?
Old 05-26-2007, 01:27 AM
baron_ baron_ is offline
Send a message via AIM to baron_
a buddy of mine uses them for a stout motor
he figures he'll blow up a muncie or a saginaw - doesn't matter what he uses....eventually
so why spend 600 a crack for a muncie when he can find saginaw's for 100
that's the best logic i've heard behind them
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 05-26-2007, 02:04 AM
ronj1977's Avatar
ronj1977 ronj1977 is offline
i run one behind my 77 t/a 400 w/#62 heads and summit 2801 cam havent had it on dyno but close to 400 hp lots of tourqe but mine is out of a truck
Old 05-26-2007, 05:43 AM
The main thing with Saginaws as I said is the number of rings on the input shaft,. The one ring input is by far the weakest with a 2.54 first gear, 2 ring has heavier gears and a 3.11 first gear, 3 ring the srongest with a 3.50 first gear. One of the quickest parts to wear out is the front bearing (input shaft) as I have two right now that has that problem, but both will be rebuilt and used.
Old 05-26-2007, 07:57 AM
Txbobcat Txbobcat is offline
I used a saginaw in my 72 GTO first 400 then 455 till I found me a muncie for over 2 years no strip use.
Old 05-26-2007, 11:24 AM
rexus31's Avatar
rexus31 rexus31 is offline
I dumped my Saginaw in favor of a Muncie. The Sag' is still in my garge with the iron bell housing. Any takers?
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior
1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top
Old 05-26-2007, 08:01 PM
I went with a Saginaw in 90 after my Muncie let go, ran 14.40's with the Muncie, going through the traps in third gear at 5200, with a 3.23 gear and 28 1/2 inch tall slicks. Got a Saginaw and put it in, went to the track the next weekend and ran 13.80's, same setup, went through the traps at 4800 in fourth. Maybe not as strong but better gearing. Would love to have a Jerico or BW T-10 but shallow pockets makes me go with what I have, and it has worked for me so far, so till I hit the lottery or a rich relative mentions me in his will I guess I'm stuck, or one of my kids gets rich and feels sorry for the ol' man. AS long as you don't beat on them all the time they are an ok transmission, as long as you get one with the right number of rings on the input shaft. By the way both I have, one is a two ring with3.11:1 first (pulled a 1.80 60ft with 3.55 gear with that one) and the other is the three ring input with 3.50:1 first. Either way no matter which one I run I'm in second before the 60ft mark. Although what works for me may not work the same for someone else and vice versa, but I love 'em. If you choose to run a Saginaw till you find something else as I said it may last you awhile as long as it's not beat on constantly.
Old 05-26-2007, 08:05 PM
By the way Baron I used to buy mine at All-City Wrecking when I lived in Columbus and ran at Trails every weekend till my engine let go at the end of the 93 season and I moved to NC in 95.
Old 05-26-2007, 09:16 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Poor boys 4 speed(like me!) I ran one behind my 455 for a few months until a swapped in the M-22. They will last if you keep your foot out of it. The one I had had a very low 1st, 3 something. -Jim
Old 05-26-2007, 11:03 PM
carcrazy carcrazy is offline
Never had much luck with one. Tore one up behind a mild 327/275 motor!
