Old 05-27-2007, 07:55 PM
KIRKW810's Avatar
KIRKW810 KIRKW810 is offline
Default manual shift shaft seal, 63'
any of you guys have a problem with the seal that the shifting rod goes into the trans, leaking? This is my second trans I've had in the car. and they have both leaked.This one I have in now is really bad. any ideas?
Old 06-17-2007, 11:51 AM
SDStanley SDStanley is offline
A Corvair seal will probably work; it is available from Clark's Corvair Parts, their part number C497: http://www.corvair.com/user-cgi/cata...=MAIN&page=115
I had to add bushings in my transmission case in the the shift shaft bores.
Old 06-18-2007, 10:05 PM
KIRKW810's Avatar
thanks for your idea, I've used Clarks before for some rear swing arm bushings and they were a great help. I,m pretty sure they'll work too.
Old 06-18-2007, 10:07 PM
KIRKW810's Avatar
did the bushings help your cause?
Old 06-24-2007, 11:39 AM
I added the bushings as part of my transmission rebuild during restoration of my 65 Corsa, but it keeps the shaft from moving radially and pushing against the seal inner diameter. I still get a "weep" of fluid out at the shifter, but not a "leak".
