Old 06-01-2007, 04:09 PM
arob63's Avatar
arob63 arob63 is offline
Default 83 trans am engine swap
Is it possible to put a pontiac 400ci into a 83 trans am? It originally came with the chevy 305ci, but that has crapped the bed. Will the factory motor mounts work or will new ones have to be fabricated? Is there an adaptor for this? My brother wants to do this swap so any info will be very helpful. Thanks
Old 06-05-2007, 07:18 PM
WarbirdTA's Avatar
WarbirdTA WarbirdTA is offline
I have seen many different engines installed into thirdgens.
You may want to post over on:
http://www.thirdgen.org
Hope this helps,
George
Old 06-07-2007, 04:39 PM
fellro fellro is offline
I've even seen magazine write-ups on this, I'm sure it's snug, but doable. Had thoughts about doing it to mine, but that will be a while...
71 Lemans T37- waiting to be worked on...
83 T/A, 305 auto, rear disc
Old 06-28-2007, 01:02 PM
84TA400 84TA400 is offline
It's not that hard, ...i have a 400 in my 84...i did it 8 years ago before anyone made engine mounts or headers for the swap...i made my own mounts and modified a set of headers, then made a trans crossmember for the th-400....easiest thing to do is give Indian Adventures a call or go on the website....they make headers and mounts that bolt right to the existing...we useed them on a friends 87 TA,...very nice stuff....or save some money and make your own...74' and up f-body mounts work, have to relocate frame mounts....68-72 a-body headers are close....collectors have to be moved and #3 tube moved.....Chiefmanyhorses.com....for Indian Adventures,...hope this helps, Billy
1984 TA, 400 PONTIAC, th-400, 4.10 12 bolt
10.49@ 127mph 1.40 60'
R/U Pontiacs in the Park 2006(SAT)
R/U Pontiacs in the Park 2007(SUN)
