Old 06-10-2007, 09:18 PM
Trucker73 Trucker73 is offline
Default choke tubes
Is anyone making repro choke tubes for the 64 326 2 barrel motors?
Old 06-10-2007, 10:52 PM
Dick Boneske's Avatar
If they are the same as '64 GTO Tripower center carb, the answer is yes. I have several sets. If the choke housing is mounted on the carb base, however, the tubes would be shorter than the GTO Tripower.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-11-2007, 03:37 AM
It is mounted on the carb base so the tripower setup would be too long
