462 Hp from Pontiac 383!!!!!
We made 462 hp at 6000 rpm and 436 ft lbs of tq at 4300 rpm. The tq was above 390 ft lbs the whole pass!! We used a Tomahawk. I think it would have made more tq with a RPM. But the motor was going in my 69 Firebird. It made all this power with NO SPACER. Although the 770 Street Avenger carb got rich above 5400 rpm. I believe the 462 hp is the tip of the iceberg if we had a better carb.
Overall I am very pleased with the power it made. Not bad for a cast iron headed pump gas motor. Almost 1.25 per cubic inch! ALMOST! LOL What will a race 383 do??? We will find out! Dave Anderson will be posting pics AND graphs. Be Cool, Ace
Am I glad I got out of the business I was in? HELL YEAH!!! |
When I saw this, I thought maybe this was the engine that was going into the project Tempest on that show on Spike-TV (the one that Lou hosts).
COOL!
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
ACE,
Congratulations, that is AWSOME!!
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Thanx guys! It is a very interesting build up. Right down to the 1979.6 bobweight!! LOL!!!
Here is the specs if anyone is interested <no links please, copy and paste only> Be Cool, Ace
Ken,
Very impressive figures....and yet, I am curious as to why you selected a camshaft with 8° additional exhaust duration when your heads have a 83.18% flow differential??? Were you monitoring EGT's during your dyno pulls??? Those heads Makes me feel good about my own headwork. My hand ported 6X-4's with a 1.660" exhaust valve (and 5 angle valve job) flowed 210 cfm @ .600" lift @ 28 in/H20 with an 87.5% flow differential...Robert Last edited by Z Code 400; 06-16-2007 at 05:41 PM. |
462 HP...
Nice job Ace, i knew you could do it, i guess there will be a lot of those stroked 350's out there now.
I wonder what it would do with one of Dude's blowers on it? Thanks for the info on this one.
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
Pontiac 383 stroker motor..........
Nice build, Kenny .
Les
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Ken neat build. I like the scraper with the holes.
Awesome flow numbers for little valves.I dare you to try a single pattern cam to compare or even a reverse split that worked well in my RAIV motor.
wow thats impressive!!! Nice Job Ken ..... Curious to see track times...
Don't toss those old 350 blocks.....
.....because as you can see they are definitely a great base for building some big power.
Nice work Ken, as always. Please keep us updated on how it runs in your '69 Firebird. Bart
And to the rest of ya all thanx. I knew this would make for a decent combo. I even have the cam in a reg hydraulic flat tappet version on a 108 lobe center! Once again thanx guys. It should be in the Sept or Oct issue of HPP. Be Cool, Ace
Congratulations Dude!!! I guess you passed my 425 guess(and by quite a bit), you should be proud. I knew there was a reason I didn't trash that old 350 block. Is Dave at SD going to offer these heads? -Jim
Much better than you could do with FACTORY iron head SBC. Who says the 350P cant compete against the 350C!
As I said there is more potential there! I have complete rotating assemblies in stock! Many different versions. And will have many of the short blocks ready to go in STOCK! Maybe I should call myself the King of small inch Pontiacs!! LOL!!! Be Cool, Ace
And how many companies are producing D-ports. |
With a small bore and kinda long stroke. I would like to see how it would perform (Dyno versa track testing) with a stock length Pontiac rod.
Ok let the scientific reasoning begin. |
FWIW Dyno sims dont show any advantage of rod change on this one as far as the 2 rod sizes mentioned. Possibly real short rod or extra long might show but have my doubts. Maybe I'll play some with the "dyno game" later.
Way to go Ace! those are some very nice numbers.
My dyno program thinks the stock stroke 350 I'm planning will make around 375-380 horses with a conservative cam. I'm still quite skeptical of this, but seeing your results gives me hope that it'll be close.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
