Old 06-16-2007, 09:11 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
Arrow Pic of headder
Ok heres the problem bolt
what worked for you?
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 06-16-2007, 09:15 PM
Brandi Kay's Avatar
I cannot get through this area to even feel for the bolt.
:range r:
Old 06-16-2007, 09:23 PM
badmojocuda badmojocuda is offline
Default bolt problem
i have to get that set of bolts from under the car on my ta. about a foot long extension, it is a pain. have you tried getting it from under the car? sorry if that was a stupid question!haha!
Old 06-16-2007, 09:27 PM
Brandi Kay's Avatar
not a stupid question at all,
i couldn't get at that angle today cause of showers and darkness.
BUT, me might having to get a foot long extension helps.
It cannot be even touched from on the top or side to even see if its there.
I will check it out tomorrow!
im in no hurry, i dont even have the new gaskets yet
:range r:
Old 06-16-2007, 09:35 PM
Default also look
you might want to see if you are going to need a swivel joint if its at a strange angle. hope it helps, good luck!
Old 06-17-2007, 02:59 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
How much effort would it be to move the steering shaft?
Old 06-17-2007, 12:05 PM
Brandi Kay's Avatar
I will look into it!
:range r:
Old 06-17-2007, 02:03 PM
FritzCat FritzCat is offline
On my car I was able to reach some of the header bolts by taking off the l/f wheel and reaching in under the fenderwell.
Old 06-18-2007, 12:14 AM
Brandi Kay's Avatar
thanks all
Im working on it!!
:range r:
Old 06-18-2007, 11:21 PM
matrix's Avatar
matrix matrix is offline
What kind of headers are those? I have some Dougs and was able to get to all the bolts from the top with a standard wrench. At most disconnect one end of the steering shaft and swing it out of the way.
